Remove these ads by
Signing UpStep 1Table dimensions and design
For the purposes of this instructable, the directions given will work if you use a different size or length table due to the absence of exact dimensions. For the curious, here are the approximate cut lengths for each member as this table was built:
Table
Top: (5) 2x6's
Legs: (4) 2x4 , ~38"
Leg cradle: (2) 2x4, ~29"
Center bracket: (1) 2x4, ~29"
Leg brace: (2) 2x4, ~38"
Two Benches
Top: (8) 2x4's
Legs: (12) 2x4, ~23"
Leg cradle: (6) 2x4, ~15"
Leg brace: (4) 2x4, ~13"
Leg brace support: (4) 2x4, ~15"
Notes:
Table legs were inset 18"
Bench outer legs were inset 12"
- The benches are very wide and comfortable. A more standard bench would probably use only three 2x4's for the top. You could also use 2x6's if you wish.
- The table itself at 30" across may be narrow if you plan on having a lot of guests and food all at the table at once. You may want to consider using an additional 2x6 for a 36" width. As we typically have less than 8 total at the table, food is located at the table ends and the table settings are in the center.
A friend and I started this little project this weekend using your design as a starting point. I liked the idea of detached benches, and your "measure twice, cut the first time, measure again, then make the final cut" way of building things.
I had to tear up a frame from who knows what off a slab in my back yard, and to my surprise found several good treated 2x4's that were perfect for this. I had enough to make the two benches, but I'll have to find another weekend to go to the Depot and get lumber for the table.
The first bench took about 2hrs, but the second one was done in less than an hour.
I found it helped to make a template for the legs out of cardboard the night before... although, the last leg attached was a little short (measure twice, cut the first time...) it was easily fixed with a little shimmy.
I also opted to only use two sets of legs on ea. bench instead of three (my benches are 6' x 1') and they feel quite sturdy.
Now I have two sturdy benches for the price of 50-75 wood screws!
Thanks!
Marine varnish is a good choice for a protective finish.
Great job!
Do you have a power saw? If not, my method is probable too labor intensive to be practical.
We used a highly unscientific method, measure twice, cut the first time, measure again and then make the final cut (repeat as necessary. Since the legs were already attached to the table, we held the piece to-be-cut up to the legs and eyeballed it. It takes some finesse, but after a few you'll get the hang of it.
If you want to calculate it, it's also pretty easy to get a rough estimate. If the brace were there, it creates a triangle. Measure the sides of the triagle; the length of the board will be approximately equal to the hypotenusehttp://en.wikipedia.org/wiki/Hypotenuse , within the width of the board (cut it long!).
Good luck =)
