3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pie in a Jar
Step 5Freeze or Bake
Freeze or Bake
You can't store these in the freezer forever - they're not sealed like jams are. But you can certainly make them up well ahead of time and freeze them for a bit.
When you're ready to bake these, take the jar out of the freezer and turn the oven on to preheat it at 375oF. Take off the lid and put the frozen jar on a plate or baking vessel so you'll have less thermal shock when it goes in the oven. Put a ring of foil around the edge of the pie for the first 45 minutes, take it off for 15.
Let it cool and either eat it out of the jar or run a knife around the edge to get it out.
And lastly, a note from Simple Simon, our inspiration:
The whole "glass shattering from temp changes" fear is the thing to worry about when you put the glass into direct contact with the change in temp, e.g. the stove, a campfire, boiling water, etc. A hot oven isn't the same thing at all because air has lousy heat transfer. Consider how you can stick your hand in a 210o oven for several seconds. Now consider sticking your hand in boiling water. Same temperature, but one causes a little discomfort while the other causes severe burns. The reason is that water transfers heat very well, as does metal (like a stove).
Don't ever stick your frozen jars into warm water. Don't ever stick your glass jar on the stove. Don't ever stick your hot glass jars into even room temp water. But frozen glass into a hot oven? Go for it. Cooks Illustrated (and their sisters, ATK and Cook's Country) have several recipes for things that go straight from freezer to oven with no trouble in the test kitchen, and they are where I got that information.
8 comments
Jul 19, 2011. 2:22 PMfoxyfabulous says:
So I made these (delicious!) and then I made them again but used a no-bake cheesecake recipe instead. And WOW -- the tiny cheesecakes were a huge hit. Thanks for this awesome idea!!
May 20, 2009. 8:59 PMartquilter says:
What a fabulous idea! Do you really need to boil everything if you're not actually canning it? Maybe just put it in the dishwasher instead? I also think it's amazing that you can put a frozen pie into a hot oven, but the other thing that amazes me is that a pie frozen solid takes the same amount of time to bake as a fresh made pie at room temperature.
May 14, 2009. 10:59 AMhoughchrst says:
I was wondering if I could just set the lid ring on the top, if it will fit, instead of trying to get the little ring of foil to stay on. I have tried the ring of foil thing and while it always works, if it stays on, it is a pain in the heinie.
May 12, 2009. 6:54 PMLauren Sommerer says:
It's nice to see that this idea is still alive and strong. Your pies look scrumptious! Thanks for linking back. Lauren (of the Simple Simon post)
May 11, 2009. 7:30 PMkatherine123 says:
I can't wait to try this! I am having a get together soon and these will be perfect, thank you.
May 11, 2009. 12:54 PMLordOlimar says:
Just for clarification, when you say "Put a ring of foil around the edge of the pie" what exactly do you mean? Are we putting the foil around the top edge of the jar? Are we covering the top of the jar/pie with foil? I'm loving this idea and am planning on attempting this at home, I just want to make sure I'm doing this step right!!
May 11, 2009. 1:17 PMbFusion says:
I think you're putting the foil around the "lip" of the crust so it doesn't burn. I have never made a pie in my life, but I think that's the general idea with pies is that outer lip above the pan (or, in this case, jar) tends to burn very easily. Someone please correct me if I'm wrong :)
May 11, 2009. 1:49 PMNotags says:
Exactly correct!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
3814
Author:scoochmaroo(Click here for more!)
Editor of the Food and Living channels, I believe making things is fundamental to being human! Follow me to see what makes me human.
