3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Piecax the Poltergeist. A Troublesome Spirit in a Box.
Poltergeist : From the German for “noisy ghost”.
A metaphysical entity which announces its presence with rapping, banging and general mischief making.
It wasn’t easy, but I’ve got one shut up in this box.  I call him Piecax.  Sometimes he will lie quietly and make you think he’s gone, then startle you with frenzied knocking.  Other times Piecax will have fun by echoing you.  Find his favourite number and he might play you a spooky tune.   Watch the video to see Piecax in action.
Thanks and credit go to JKestner whose  Knock Block gave me the inspiration for this project.
Step 1The Box
The Box
I did this first so I wouldn’t be waiting for varnish to dry once I’d built the circuitry.
I started with a cheap softwood box from a craft shop.  I clamped a rotary sander upside-down in a vice and rounded the corners and smoothed the sides, starting with a coarse sanding sheet and finishing off with fine.  A final rub over with very fine paper and I had a smooth rounded box but a bit of a boring colour.
To bring out the grain I gave it two coats of walnut woodstain  and then for the gloss, three coats of yacht varnish.  The first coat was diluted with thinners to make it soak into the wood and give it more hardness and a good base for the other coats.
A quick raid on my sons' lego sets and I had a casket fit for a ghost.
105 comments
1-40 of 105next »
Oct 29, 2011. 12:03 AMmadbutler says:
Hi Andy how is your scope coming along. Have you had a look at Admiral Aaron Ravensdales instructable? http://www.instructables.com/id/Poltergeist/. I have just spoted it/ His uses 2 piezo sounders, put still uses one like you did as a mic. Do you think there is a change in the 08m2's programing language that has an issue with changing it back to an output as he used a second piezo to play the sound while his code is very similar? I still would love to get this going with one piezo to cut the cost down so students can make this awesome instructable
Thanks again for this great project
Madbutler
ps Are you working on any other 08m2 inventions using this great new chip with touch capabilities and a bigger memory?
Oct 27, 2011. 10:01 PMAdmiral Aaron Ravensdale says:
Here is my version with the latest PicAxe 08M2 Chip.
Thanks for your instruction AndyGadget...
I do some changes in the speaker / microphone section and add a flash signal durin knock!
Cheers
Sep 1, 2011. 9:22 AMjessyratfink says:
This is fantastic! I don't know how I missed this one.
Sep 29, 2011. 10:16 PMAdmiral Aaron Ravensdale says:
Hi I just finished my version of your poltergeist and use the 08m2 chip. I change the code a little and use a single microphone and a speaker. I also add a flash with works with the knock.
I hope i found until next week some time to post it here. But you can see it still on my website http://www.steampunk-design.de/useite.php?Klopfgeist pls change into english language!
cheers
Oct 6, 2011. 11:10 PMmadbutler says:
Can I possibly get the code and diagram for the change made to get this going with the 08m2 chip.
Oct 27, 2011. 9:59 PMAdmiral Aaron Ravensdale says:
Oct 23, 2011. 12:36 PMbotronics says:
I built a box "Don't Open Till Doomsday" based on the Outer Limits episode with the same name.I shorten the program just to do the knocking and change the port I/O.  Added a opamp to boost the signal from the piezo.  Works very well. Thanks for sharing. I still need to make "the creature" that lives inside using Sculpey III. Photos at this link.
Aug 8, 2011. 10:39 PMmadbutler says:
Does anyone know how to get this going with the new 08m2 chip, I have changed the names to c.4 etc and mic input but it does not work nothing happens? I have students that love making the knock box at my school but new chips wont work.
Aug 9, 2011. 1:49 PMmadbutler says:
It does program the chip with the old code but the piezo does not respond. I changed the pin names and the input further down the code and does the same thing. I also tried it in second knock box with a bs270 mosfet and the mosfet got extremely hot you could smell it cooking, yet changing it back to the old chip it worked fine. Dont know if this information helps you with any problem solving. Thanks for your time
Aug 11, 2011. 3:42 PMmadbutler says:
Thanks for the time you are spending on this. I have been looking at different things. I added an led to the piezo and it flashes when the piezo is tapped each time, so it seems to pick up the knocks, but not record them. I dont know too much about programming but is the memory allocation different on the m2 chips and the m2 information notes mention some command replacements but I cannot see any in the script that needs changed. It also mentions peek commands but this means nothing to me (yet)
thanks again
Aug 14, 2011. 2:50 PMmadbutler says:
I have been experimenting I added a readadc on the pin and assigned it to b9 and changed the mic to b9 to see if it would play something back. it does but irrigular to taps given to the piezo. Reading through the manual the 08m2 has a calibadc where the variable receives the adc reading i dont know if this can be used instead to read the mic pulses as it does on the readadc. There is also a Count pulses on an input pin command but I guess this would just count them and not give the same rhythm back. You are such a knowledgable chap this info is probably miles off track.
Aug 25, 2011. 7:27 PMmadbutler says:
Just wondering if you got back to looking at this? I don't blame you if you put this in the too hard basket. Its been bugging me too.
With my limited electronic knowledge I added a transistor to boost the signal, but this made it over sensitive (recorded knocks and every other vibration) and then you cant play it back through the piezo. Tried even a capacitor with similar luck. It seems it needs just a little stronger signal but my lack of knowledge to do this lets me down.
May 24, 2011. 3:01 PMmischka says:
LOL, you made my day, boy!
May 18, 2011. 1:45 PMproject dude says:
Love the project! Just wondering if you have a supplies list or something like that so i know what to get. Thanks.
May 18, 2011. 6:00 PMproject dude says:
Thanks a bunch for the reply! I viewed this before and I seem to remember a parts list, but i couldn't remember what was on it. Thanks for the reply. :)
Mar 20, 2011. 1:19 PMstringstretcher says:
I need one of these! Love the idea, and you have explained it very well. Thank you! Can you program a "call and response?" In other words, can the box answer your "Shave and a haircut" knock with "two bits?" I have never tried programming a microprocessor like this. Oh boy, a new hobby!
Jan 23, 2011. 2:12 PMTedfi says:
I would like to go to Michaels and look for the box. Does anyone know what size this one is?
Mar 11, 2011. 8:19 PMTedfi says:
Dear AndyGadget,
My friend is helping me build this but neither of us can program in basic. What do we do now? Is there a way around it?
Thanks,
Ted
Mar 12, 2011. 5:52 PMTedfi says:
Dear AndyGadget,
I gave him your reply and he says that he does not have a basic program to do the programming. He says that when he plugs the cable in he will need a program like basic. He does not understand and I am totally illiterate. What do I tell him... S O R R Y for being so stupid.
Mar 5, 2011. 1:15 PMplayfulplans says:
Amazing. Period!
Nov 3, 2010. 1:29 PMmadbutler says:
excellent project I have built this with a 8m chip and the kids love it.
Any idea about how to adapt this to an picaxe 18m2 chip as it has more memory to add more songs to different knocks etc and pins can be set to in/out. I know how to change knock amounts and tunes, but I do not know how to change the first part to get it working. Ive been experimenting on a breadboard with no luck. Any help would be appreciated.
I have set up:
pin 1 = pin 14
Pin 2 = pin 3
pin 3 = pin 10
Pin 5 = Pin 6
Pin 7 = Pin 2
Pin 9 = Pin 5
MadButler
Nov 3, 2010. 8:48 PMmadbutler says:
Thanks for that info, im a few steps closer to getting it going but it does some weird things, like when i tap on the piezo sounder the light flashes and only if the led stays on the motor pulses twice and waits 4-5 seconds and pulses again and keeps doing this until i tap it again. I had a scan through the script and cant see anything there that might confuse the program.
by the way your instructables are really awsome, hope to see more cool things to do with the picaxe chips. i will be having a go at the tic tac instructable once i hunt down a slide resistor
Nov 2, 2010. 4:41 PMpbecker83 says:
I used a vibrating pager motor like the one seen here (http://www.radioshack.com/product/index.jsp?productId=2914700) . I glued it to the bottom circuit board and let the hole thing lay free inside the casket. Looking forward to any future makes. Starting to eyeball your "TicTacTunes".
Patrick
Oct 31, 2010. 2:38 PMpbecker83 says:
Finally got around to building my own called "Terminal" The Haunted Mummy. Awesome build Andygadget. Love it.
Video
http://www.youtube.com/watch?v=u81YIyu9GEE
Pictures
http://www.flickr.com/photos/55301458@N03/
1-40 of 105next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:AndyGadget
