3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Piecax the Poltergeist. A Troublesome Spirit in a Box.
Step 4Putting the Ghost in the Box.
  • last photo ←
With the box size I used, everything goes in pretty easily and neatly. You will need to adapt the layout if you use a different size or shape of box.
The battery is held in with double-sided sticky foam so it can be replaced.  The circuit board in held in the same way, and has to go in before the motor if you're using a small box.
Gluing a small piece of brass strip to the lid where the knocker hits gives a sharper knock and helps the knocker to return quickly.  The final picture shows a piece of foam glued in to dampen the 'clunk' when the arm returns.
Click HERE for information about the standard training video for containment of supernatural beings.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:AndyGadget
