Introduction: Pier 9 Resource: Accessing Custom Post Processors on a Mac in Fusion 360
Picture of Pier 9 Resource: Accessing Custom Post Processors on a Mac in Fusion 360
This Instructable is for Workshop Users at Pier 9. However, it's relevant to anyone who:
1. Uses Fusion 360 on a Mac
2. Has a custom post processor
When Mac users post process their CAM files to turn them into G-code, by default Fusion 360 only shows Generic Posts. This Instructable will show you where to put your custom post processors so you can access them.
Step 1: Enable Access to A360 Drive
Picture of Enable Access to A360  Drive
1. Go to A360.
2. Right click your image in the top right corner--your profile--and click Settings.
3. Enable access to the A360 drive with the slider bar.
Step 2: CAMPosts
Picture of CAMPosts
1. Click the dropdown next to A360 at the top of the screen, and select A360 drive. It may take a few moments to load.
2. Click "New Folder" in the upper right corner and create a folder called CAMPosts.
Step 3: Upload CPS File
Picture of Upload CPS File
1. Double click the new folder and click Upload in the top right corner.
2. Select your CPS file and click Open.
Step 4: Preferences in Fusion
Picture of Preferences in Fusion
1. Restart Fusion 360.
2. Go to your profile by clicking your name in one of the upper corners. In the dropdown, select Preferences.
3. Under General on the left hand side, click CAM.
4. Select the box next to "Enable Cloud Libraries" to allow access to your A360 post processors.
Step 5: Post Process!
Picture of Post Process!
1. Right click Setup 1 and select Post process.
2. Set the Source to My Cloud Posts.
3. Your post processor should appear in the dropdown next to Post processor.
4. Add a program number and comment, and hit OK to generate your G-code!
Step 6: Troubleshooting
If you can't get Cloud posts to sync up, try following this guide to use Personal posts instead.
Scroll down to the bottom to see instructions for a Mac.
About This Instructable
590views
6favorites
License:
More by Julie Kumar:Fusion and CAMplete Workflow for Using the Matsuura MX-330 at Pier 9Self ReflectivePier 9 Resource: DMS Certification Part II: Machining
Add instructable to:
