Piezoelectric Nanofiber Electricity Shoes PROTOTYPE #1
Published
Introduction: Piezoelectric Nanofiber Electricity Shoes PROTOTYPE #1
About: Hello! I am a human who has a passion for innovation, science and technology. I decided to create this account to have a place to post my not so serious ideas, so even my half-baked invention projects might ...
Nanotechnology can help us produce green energy through the science of piezoelectricity, which is essentially electricity produced through mechanical stress (the work done by gravity on the soles of your shoes). In the future, I hope to come up with something simple and cheap that everyone can make; so that just by walking, one would be able to charge their phone, or generate electricity and store in batteries. Please feel free to take my idea and experiment with it as it is currently a work in progress.
Disclaimer! --> I created this instructable before perfecting the invention, it does work but the electricity produced by the piezoelectric effect is actually too weak. This invention is still a work in progress as I will be experimenting with different (and more efficient) materials. Thank you!!
Step 1: Gather Materials
- Shoes with penetrable soles and no heels
- Barium Titanate (99.99%)
- Methanol solution
- Copper Sheets
- Electrode wires
- Hollow attachable heel
- Chargeable battery that fits in hollow heel
Step 2: Add a Few Drops of Methanol Solution Onto Your Copper Sheet
This is just the solution for the powder so you can spread the titanate all over the surface of the copper plate, later on your alcohol will evaporate off.
Step 3: Spread Your Powder Over the Surface of Your Copper Plate
Wait till it has dried ( which may take some time) but this essentially means that your alcohol has evaporated and you can move onto the next step because you should be left with a thin layer of Barium titanate.
Step 4: Put on the Other Copper Plate
Make sure you leave a little surface of copper hanging out on each cell, this is where your electrode will clip onto, barium titanate is your piezoelectric substance that you're using so as the material is sandwiched between two conductive plates it will produce a voltage, this is your nanofiber-based piezoelectric energy generator that has a scalable power, I recommend you make eight of these cells for the shoes because it's essentially an green electrical device that scavenges mechanical energy from its environment, and so you could produce a good amount of pure green energy by just walking around!
Step 5: Add Your Electrodes
This will allow the electricity generated through your mechanical pressure to be sent to the battery, but first you need to check it.
Step 6: Check Your Voltage
You can do guess and check work to see whether you're satisfied with the amount of energy your cell produces under mechanical stress.
Step 7: Mount the Cell on the Inside Ball of Your Shoe, Then Drill a Hole Through the Rubber Soles
The ball of your shoe is on the inside where the heel will go, layer cells on top of each other to generate more force. To make the design more comfortable, add padding over the shoe, then string the wires through the drilled hole in the sole.
Step 8: Transform Your Hollow Heel Into a Rechargeable Battery
for the sake of prototyping I just bought multiple tiny rechargeable batteries and had the wires connect through there and then it looks like a heel, but you can open it up and use the batteries to charge your phone.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    Try do go through the airport security check with these.. :-D
    Nice idea anyway.. Does this even work?
    Ha. Yes that would be hard to explain. Especially after the shoe bomber incident and the young lady from MIT that almost go shot wearing a harmless LED blinker on her blouse.
    But you are wise to ask. No, it doesn't work. The author is having us on a bit, I think :)
    I think the author is putting us on.
    Nano-fine Barium Titanate has to be sintered into a crystal at 1200 Deg C in order for piezoelectric properties to exist. You can't sprinkle it between two pieces of PCB and expect to produce a voltage under pressure. You need a crystal lattice for that and fine particles smoothed out with Methanol do not magically blend into a crystal.
    The scope trace shown is just displaying 462uV of noise. There's no specification for the average voltage per cell with respect to applied force. None of the photographs or descriptions show the device installed in a shoe or connected to a charging circuit. You can't connect a piezo device to a battery and expect it to charge the battery. It's a lot more complicated than that, even if it didn't require a 10,000 mile walk to charge one 3V Lipo battery. There not that much energy in the walking around people typically do.
    I can't make any scientific sense out of Step 6. Based on the size of the PCB shown there is no way I could get 8 of them in a shoe my size, and I wear a big shoe.
    So, I think this article is a bit of science humor.
    NetZener
