Pimp Your Car's Stereo. Adding Bluetooth to Your Head-unit. ($2,- Project)
66,342
257
35
Posted in TechnologyElectronics
Introduction: Pimp Your Car's Stereo. Adding Bluetooth to Your Head-unit. ($2,- Project)
About: Fulltime mechanic and parttime creative handyman. Lover of meat. (Preferably grilled or smoked)
Modern times ask for modern solutions.
Many of us drive cars older than the modern smartphone. And there lies a problem. How you're gonna stream your favorite music to your speakers.
A lot of cars have a AUX (auxiliary) port to connect devices such as your smartphone. But having loose cables in your car and connecting your phone every single time... That's like having a casette-tape with a jackplug sticking out of it.
This solution took me about 3 hours to complete.
Step 1: Sick of Wires Dangling Around.
Before you begin, please know that a car's stereo is delicate electronics. Be gentle. :) Proceed at your own risk!
The first picture shows the old situation. A jack plug sticking out the front panel. The second shows a solution you can find on Ebay for around $2,-. This is a stick that's powered off the USB-socket of your head unit. (a phone charger also works)
This device makes a bluetooth connection and plays everything you would hear on your phone through the jack cable.
A fine solution, but not clean. Also, you have to change between the bluetooth-device and your USB-stick if you'd like to listen to that source.
There is a better way.
Step 2: Take Apart That Head-unit.
Use some tools to take out the stereo from your ride.
This model is a Sony CDX-GT450U. (about 4-5 years old) I found it really nice to work on. Easy to take apart.
What you want is to measure the pins on the header the detachable front connects to, since that's provided with USB 5V and connects to the aux-socket. The pins are measured on the bottom of the main PCB, so nearly all metal casing parts have to be unscrewed.
Start by taking the upper plate off. From here you can see the space that's unused in this casing. On the right, there is a nice, big gap between the CD-player module and the side of the radio. That is where we lay our focus on.
But first we need some measurements. Take the plastic plate off which has the CD-slot. On this model, it's three screws on the frontside and some clips on the sides.
Now you can take away some more screws. Three on the PCB, two on the far ends of the backplate and two more on the upper rear end of the sides. You end with the main PCB with the CD-drive on top and the backplate still attached. Don't try to remove the backplate, since the amplifier module is attached there somwhat permanently.
With a bit of gentle fiddling, the CD-drive can be removed from a socket on the main PCB. I didn't disconnect the flat cable that's between the drive and the PCB because i was affraid to break it. :)
Flip over what's left of the radio and start measuring.
Step 3: Master Your Measuring Skills!
Take the jack cable that came with the USB bluetooth reciever and put in in the socket on the front panel.
Take any old USB cable (USB A Male on one side) And cut it in half. On the USB cable, we only need the red (positive) and black (negative) wire. Stick this cable in the socket as well. Attach the front to the board.
Take any multimeter and set it for resistance mode. What you do now is you take one of the probes on your multimeter and hold it against one of the USB wires. Now you try to find a place where the resistance from the cable to the connector on the PCB is (near to) zero. Take note of these positions. This is where you solder the cables onto.
You can do the same for the jackcable. Measure between the front contact of the cable and the PCB for example and take note of your measurements.
On this board, Sony was so kind to provide me with a nice, unused place where another header should be. Or maby the same sort of header, but a different model. The point is, this can be used perfectly to connect wires through the hole, as these contacts match the original header.
The dots of solder covering the holes are easily punched through with a sharp tool with a small diameter. I used a pointy voltage detector. Maby the probes on your multimeter are small enough.
Step 4: Hack That Stick!
Remove the outer case from the stick. Here you see the USB header and the jack socket. I took them both off.
First, connect the stick to a powerbank (or any USB powersource) and make sure you got the polarity correct. The outer pins are the ones used to power the tiny board.
Next, use some desoldering whick (lytze) and a soldering iron to remove as much solder as possible. Then apply some tension on the headers and try to free the contacts using a soldering iron. Be careful not to break the board or destroy the contacts.
You should end up with a tiny piece of PCB. Solder the wires on according to the measurements you did earlyer with the pin header and the cables on the head unit. I snipped the jack cable that came with the stick in two and measured the colours and matched them with my previous measurements. But any colour is correct, as long as you match the contacts of the socket on the stick to those of the head unit.
If you use any other cable, make sure it's rather flexible. The islands on the stick are not built for much force. That's why i put some hotglue on the wires where the jack port used to be and some more to fix the wire and the PCB to the original casing.
The last photo shows a stick with wires dangling out.
Step 5: Put It in Place.
Here i found out the CD-drive can be disconnected. From here out, it's really easy soldering.
Cut the wires sticking out of your newly made reciever to the desired length, strip them down and solder them where you thought they should be placed, based on your measurements.
It should look like the second picture.
Step 6: Testing
Put everything back together like you took it apart, leaving the top cover off. Take it for a test in your car. If something is wrong, try to solve it.
Assuming you have followed this instructable correctly, and my directions were clear, you can now connect your phone (or other bluetooth device) and listen to music in your car, wireless!
So take it out one more time, and fix the reciever in place with some hotglue. I placed the unit as close to the plastic front cover as possible, providing the best reception of wireless music.
Step 7: We've Got a Wave in the Air...
Admire your work. You've kept full functionality of your head unit and added a bluetooth audio-connection, costing you less than 2 litres of fuel. No more sloppy cables dangling around.
This instructable can be used on nearly every car stereo that has both a AUX-in and a 5V out. To power the stick, you can use a phone charger as well.
I doubt if there is a cheaper way to get the same result.
Happy soldering! :D
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    35 Comments
    Nice Instructable. Anyone have any suggestions for adding bluetooth to an older car (2004) stereo that doesn't have an AUX-In? (I can't just replace the unit because it also controls other functions.)
    If you have a *really* old head unit - with no Aux input and a "proper" analogue volume knob, that can often be the starting point for feeding a signal
    FM transmitter that plugs into the cigarette adapter that has Bluetooth capabilities
    FM transmitter is ok, but the sound quality is not all that.
    Search "ls1tech aux input". Go to the first page of the thread. I am going to assume you're up to speed with any of this since you're on Instructables. This is tapping into a line-level (?) audio signal. If you have a factory satellite receiver, you should also be able to similarly tap/break into its audio wires; right outside the radio even.
    Now that you can follow the tapping, I'll suggest a solution to your question specifically. You can get a 12V AUDIO Bluetooth board by Sure on a place named Parts Express. Get your switched voltage, ground and do the tap/break with a double pole-double throw switch instead. You should now have what you're looking for.
    I have been checking into this for a similar reason (integrated information center display) for someone else. I have not done it yet, but am very sure this will work. If not, there would only be a small manipulation to make it work. These are this decade's most useful hack, IMO, LOL. Good luck.
    A lot of suggestions have been done.
    It's a bit dependant on your head unit. Maby you can ask your dealer if the radio has an aux in for a changer or similar.
    Another option is to mod what's already there. Tape or CD input.
    So a specific answer can not be given without more input...
    You can also get a RF modulator that attaches inline to your deck's antenna input (i.e. the antenna input on the back of the radio). You connect your phone (or Bluetooth audio dongle like the one in this instructable) to a 3.5mm jack input to the modulator, and tune your FM radio to the specific frequency and you get your "aux" input. They have been around for a long while so you might want to shop around since there might be ones build with Bluetooth now instead of the 3.5mm jack.
    If you don't want to use the tape input, you can wire directly into the head is, but it will be a one-way process.
    A lot of older car stereos have unused inputs used for fancy options of the day like trunk cd changers or whatever. My cars 03 stereo has that option and originally had a tape option but my car doesn't have them and thus the inputs in the back are unused. To add this adaptation all you need to do is find out how to enable one of these options on your receiver to "trick" your receiver as in: put it on "tape" to get bluetooth. usually this is as simple as connecting 2 wires and theres videos all over youtube for specific stereos and units. Once you enable an option find power and the input terminals on the head and make sure you don't blow you usb. You might need to patch a wire from a cigarette lighter to the usb power adapter or something to power the BT adapter without blowing it.
    Very cool. Thinking of doing it to a head unit I bought. Had to choose between some different features.
    Bluetooth had to be left out. Only thing I regretted. But now it seems a lot more doable!
    Good luck with that.
    I'm interested in your result. Please leave a message if things worked out as planned. :)
    I'm sure you had fun doing this, and you have a nice feeling of satisfaction. There is something to be said for the nice tidy look of having everything behind the scenes instead of dangling around the dashboard. My guess is that there are a lot of people looking at this, liking it, but thinking they can't or don't want to do something like it themselves. I found a reasonable alternative that is fairly low cost.
    I've tried at least a half dozen BT speakers over the years (some standalone, some linking to an FM channel, etc), mainly for phone calls, and only recently found a solution that I re-e-e-ally like. It's the Himbox HB01 (not including a link because it's easy to find). It's fairly compact, the microphone pickup is decent, and it plugs directly into USB power and aux-in. Also, it's cheap. :-) There are still a few wires dangling about, but they are short and black, so not too bad.
    The mildly crazy part is that I got a little lazy and tired of switching to AUX on my head unit when I was getting a phone call or was using Google Maps. So, I bought a small and cheap USB-powered speaker. I plug the BT into that. I realize that that just means I have a more traditional standalone BT unit that happens to be powered by USB. Still, I have the option of plugging into my aux-in port if I want to hear higher quality sound.
    Thanks for your input.
    The himbox I found is priced around 20 pounds? that's rather expensive compared to my $2,- solution...
    You can always choose to order such a stick and use it like it was originally designed. I wrote about this in the ible.
    I agree completely. I was just offering a possibility for lazy people. Solving sloth with cash. :-)
    Goed zo. Ben benieuwd!
    Deel je resultaat maar als reactie. :)
    The device is listed as unbranded/generic.
    Search for "bluetooth music reciever" on Ebay and you should find it.
    the ones I came up with are super tiny and look hard to mod. I will post if I find the one in the guide
