Pimp Your Mini Lighthouse
Introduction: Pimp Your Mini Lighthouse
Here is a mini lighthouse that comes from France (Brittany) which was illuminated by a candle,
I removed the candle and inserted two electronic circuits a NE555 for the brightness of the LED and a 74HC04 for the LDR and the Battery.
the battery is 4.8V NiMh in four AAA battery holder.
Step 1: Screenshots of the Two Modules Used for the Headlight
Here are the screenshots of the two modules used for the headlight.
The schemas, PCB and SVG-PCB are in the attached ZIP archive
Step 2: Construction
Connect the 4.8V battery to the LDR module input.
The LDR must be glued to the outside of the Headlight to operate properly. Connect the room LED and the NE555 module input to the LDR module output. Connect the flash LED to the output of the NE555 module WARNING carefully respect the polarities of the modules and LEDs.
Step 3: Material and Files
1 epoxy PCB presenzitised 100 x 75 mm, soldering iron, solder, drill 0.8mm, acétone
1 x 74HC04
1 x Potentiometer 200K
4 x Pin Header
1 x tantalum condensator 10µF
1 x 100nF condensator
1 x LDR
1 x NE555
1 x DIL 8 support
1 x Pin Header
1 x 10nF condensator
1 x 330K resistor
1x 10K resistor
1 x 33 Ohms resistor
1 x white LED
flashing LED for Kicad 07/2013 version
transparent for insolation SVG open with internet explorer or InkScape
Kicad old version 2013 link: search or Kicad 2013 old version
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
