Remove these ads by
Signing UpStep 1Gather Materials
-wax
-USB drive
-carving tools + saw
-Casting house
This can be tricky. You're going to need a block of wax to carve (actually some woods will work too, as long as they burn away cleanly and don't leave too much ash residue.) Wax by Kerr or Ferris is designed for carving and clean burnouts, it's what i'm using here. There are different hardnesses, in this project I'll be using green wax, which is both hard and brittle, but takes detail well and allows for very thin walls.
You will need a USB drive. You probably won't ruin it during this project, but you could, and it will probably void your warranty. Feel free to try it with an old 32mb drive or something first if you're unsure. I'm going ahead with my 1G drive because what can I say, I'm fearless.
You will need a place to have this cast. You can take it to a casting house (easy, fast, and pretty inexpensive) or you can cast it yourself. I won't cover that here.
You will need carving tools. You can make do with some scrapers, pointy utility knives, or dental tools, but the real king of speed and flexibility here is a rotary tool like a dremel or a foredom. You'll want some ball burrs, but try not to get anything too fine-toothed because it will gum up with wax pretty fast. A jeweller's saw frame with a spiral wax blade is reccomended, but if you've got a bandsaw or something that can do it, by all means use that.
That should be it.
thanks for the idea
DTA
I always eject my flash drive; I have several portable apps on said flash drive and if they're not properly closed before removing my flash drive, data on that flash drive could be corrupted.
Besides, it takes ten seconds at the most.
interestingly the computers at the school i used to go to (just finished :D) actually had the safety eject thing disabled (they were secruity freaks - although i figured out how to get around everything i actually wanted to lol)
It doesn't really take that long, but its just another 10 seconds unnecessarily wasted.
They blocked a shortcut to C:\ already but they need CMD for troubleshooting (we use terminals connecting to like 20 servers and with CMD you can see what server you're on so they know where the problem is)
But like i said they didn't disable batch files which can do all the same things.
(although i think they just blocked CMD on student and teacher accounts, im pretty sure the computing teachers still had access to it)
and if they blocked shortcuts to C:\, try right clicking on the start menu, clicking browse and just going back a few directories - that actually worked at my school
A)what metal is it silver?
B)how do you get the cap to stay on?
C)why rivets why not something else?i dont have rivets
D)and last of all about how much did it cost to get it cast?
i loved this im going to try to make it
