The choices for affordable modern cribs on the market are limited. So, here are instructions on how to turn your $100 IKEA crib into a designer piece.
Remove these ads by
Signing UpStep 1Materials and tools needed
Materials
- IKEA Gulliver Crib, 1 (all hardware included)
- 1/4' birch veneer plywood, 2 sheets
- 1/2' metal screw plugs, 8
Tools
- table saw (optional, your local home improvement store can cut to size)
- drill
- 1/2' drill bit
- wood glue
- sand paper and wood filler (optional)
- paint brush, primer and paint
- pencil
Tools
- drill
- 1/2' drill bit
- wood glue
- pencil
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
http://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
