Step 3Building A Frame
It should be noted here that I am not a carpenter, and this was my first major project, so its quite possible that the way I went around this was not the best. I was learning as I went. Hopefully you have someplace more appropriate than your kitchen floor to build too!
I got all my wood cut at Home Depot, a great option if you don't have your own power tools. The sides are 3/4" thick paint grade pine. I couldn't miter the corners because HD wouldn't do that for me, although obviously that is a nicer option if you have the tools for it. I just laid down my sides, glued them with wood glue, and tightened them down with the 90 degree clamps. After giving them a little time to dry I screwed them down with wood screws. If I was to do this again, I would make the long sides screw onto the short sides rather than the other way around. It would mean you don't have a seam showing on the side you look at (although you would have screws), plus I could then use those pressure clamps to hold things together more tightly. They don't make clamps long enough for the long side.
Note in the detail photo I measured 3/8" in (half of the wood's width of 3/4") and lightly scored a line so I would have a visual guide of where the screws go. I did this all over the place and it was extremely helpful. Later you can just sand these out or paint over them.
Add Comment
