Introduction: Pinch Pot Birds
Picture of Pinch Pot Birds
By; Ricky Castillo, Jasmin Diaz, and Mya Caetano.
Step 1: Size
Picture of Size
Grab clay the size of a tennis ball and roll it into a ball until smooth.
Step 2: How to Start
Picture of How to Start
Push your thumb into the center of the ball of clay (firmly). Enough
Step 3: Forming
Picture of Forming
One you've made your beginning hole, keep stretching it open until the walls around and beneath are equally thick.
Step 4: Example
Picture of Example
It should look somewhat like this.
Step 5: Shaving
Picture of Shaving
Cut the rim of the pot to make it smooth and straight.
Step 6:
Picture of
Cut as much as you need to make it straight.
Step 7: Example
Picture of Example
The rim should look something like this after.
Step 8: Forming
Picture of Forming
Scorn and split the edge of the pot.
Step 9: Continue
Picture of Continue
Place the two edges together.
Step 10: Glueing
Picture of Glueing
Place the vinegar on both sides and hold them together.
Step 11: Continue
Picture of Continue
Once the edges are firmly attached to each other, then scorn and split the top of the seal again.
Step 12: Role a Piece of Clay
Picture of Role a Piece of Clay
Make it long enough to cover the split on top.
Step 13: Solidifing
Picture of Solidifing
Place the slim piece of clay where the rims were once to solidify the bond together.
Step 14: Smooth Out the Split
Picture of Smooth Out the Split
With your fingers smooth the top of the body.
Step 15: Continue
Picture of Continue
Make it as smooth as possible.
Step 16: Forming the Body
Picture of Forming the Body
Use force to shape the body to make it look like a bird. Raise the back of the bird to make a tail.
Step 17: Example
Picture of Example
Final look .
Step 18: Shaping the Head
Picture of Shaping the Head
Raise the front of the body to make it look like a head. Pinch the front of the face to make a beak.
Step 19: Final Steps
Picture of Final Steps
Make two small holes in the front of the birds neck. It is used for you to pour out what ever you put in it. Salt, pepper, or etc.
Step 20: Final Steps
You can use a tool or not to make a hole on the bottom. It is used to fill the bird with anything you want.
Step 21: Example After
Picture of Example After
The hole should look like this.
pfred2 (author)2016-09-21
I had to check this out to see what a pinch pot bird was. I think I might know now? It is a shaker of some kind, isn't it?
MrsStearns (author)pfred22016-09-28
Yes, it's a shaker. You can add salt, pepper, or anything you would like to add!
About This Instructable
752views
13favorites
License:
More by MrsStearns:Ceramic CupcakeSlab LetterCoil Face Jug
Add instructable to:
