Pine Resin Torch
Introduction: Pine Resin Torch
“Here’s the scenario: You are stranded somewhere in one of the wast
forests of the northern hemisphere, it’s winter, it’s cold and you have only a half an hour until the sun sets when you realize you have to walk 3 more hours to safety, the terrain is too dangerous to walk in the darkness and waiting until morning would get you killed by hypothermia even if you could construct some kind of a shelter, the bottom line is that you need to make some kind of a torch from materials that are common in the forest, using your EDC tools, and walk it out.” – this was the challenge given to me by a friend who I usually hike with, and this is my response:
Step 1: Tools and Materials
Materials I used:
· Pine resin as fuel – resin circulates throughout the pine tree and serves to seal the wounds from pathogens when the tree is damaged (even superficially), that’s why you can find pine resin anywhere you can find pine trees and basically you can find pine trees anywhere you can find a forest, with more than 120 species within the Pinus genus they’re the most widespread trees on the northern hemisphere.
· Bracket fungus as container – again, they’re abundant, especially in old forests, and can be harvested all year round as they’re perennials. I used Red-Belt Conk (Fomitopsis pinicola), but any good sized conk would work, Horse Hoof Fungus (Fomes fomentarius) being the most widespread and known.
· A forked branch as handle – I’m confident that you’ll easily find this item in any forest.
Tools I used:
· Pocket knife – any small folding knife would “cut it”, you don’t need nothing fancy
· Lighter – or matches, or firesteel, or whatever means of fire lighting you prefer
Both are pretty basic, when it comes to Everyday Carry.
Step 2: Assembling the Pine Resin Torch
Once you got the ingredients, start by carving a hole in the top of the conk, this will hold the resin a.k.a. fuel, try making the hole as deep as you can without puncturing the bottom of the fungus, a deep hole fits more fuel and increases burn time; hole width also influences burn time: a wide hole decreases burn time because the fuel burns on a bigger surface, but gives more light.
Next step is to add a handle: sharpen the tips of the forked branch and push them against the conk’s back (the back being the side that was attached to the stump), take your trusty knife and drill holes where they left impressions then insert the branch’s prongs in the holes you drilled, use some force to push them in, you don’t want it falling off, trust me.
That’s it, the torch is complete, just add a handful of resin and light it up.
Step 3: Final Thoughts & Conclusions
A handful of pine resin will burn for a good half an hour but more clumps can be added along the way to keep the flame alive, one thing to look out for is that if you add too much it will overflow and start dripping fiery drops of liquefied resin that are relatively hard to put out, can severely burn your skin or clothes, or even start a forest fire, please be mindful of that.
The conk I used was fresh and living so it had a good amount of moisture in it, I figure this was the reason that despite burning resin in it for several hours it’s only burnt superficially, I’m confident that it could be used for days or even weeks before it burns trough.
All in all it was an interesting challenge, and I’m really curious on your input, how would you make this pine resin torch simpler to build/use or with even less materials or tools.
You may copy this instructable as long as you link back to my blog ( or original article (
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    Seriously good instructable! A very handy tip for campers and hikers, with a strong application of good sense! You could even use this method to move fire among multiple camp fires in a group camp with safety and ease. Well done.
    Really great idea! Nicely documented
    Thinking outside-the-box is what surviving is all about; very effective! (Now, lets hope you never actually need this, however if you do, YAAAAY)!
    Verry cool. I have got to try this!
    And another survival skill added to my list. Thanks!
    If you setup some kind of bark shield at the back, you can prevent the torch from directing light at your eyes. This will increase the effectiveness because you have only reflected light hitting your eyes. It's the difference of using a flashlight and an open lantern.
    Neat idea and a great use of readily available materials.
    Adding a shield never crossed my mind, great idea!
