loading
Hi everyone today i will show you how you can host your own MCPC server on your RPi.
Its compatible with Kodi.(Tested with RaspBMC).
Step 1: SSH(ing):
First of all you need to find the IP of your Pi
Kodi:
1.Go to 'System'
2.In the menu under the button select 'System Information'
3.See the text written after 'IP address'
4.Thats your IP
Other OS(s)
Well you can find a tutorial online easily.
Now..
Download Putty
http://the.earth.li/~sgtatham/putty/latest/x86/put...
Well
Then,
Open it
Type the IP you found in the previous tutorial in the box 'Host Name(or IP address)
Well leave everything else as it is.
You can do a save if you want.
Now the screen should be something like
http://prntscr.com/6e6oyt
Go and press Open
Well Done!!!! (If you did it right it will ask you your username)
Step 2: Installing Java:
Well now we have to install java for the RPi.
1.Login : UserName - pi Password - raspberry (can be different with different OS(s)
2.Add RPi Foundation Repo - Type in 'sudo nano /etc/apt/sources.list' (without ')
Now in that file add a line 'deb http://archive.raspberrypi.org/debian/ wheezy main untested' (without ')
3. Finally run 'sudo apt-get update && sudo apt-get install oracle-java7-jre'
Well Done Again.. (If you even reached till here)
Step 3: Get MC
Well im using MC Forge so here's how to setup
Download the latest version of forge for the version of MCPC you have.
Open it
Now select Install Server
Select a new folder.
Something like this should be seen:
http://prntscr.com/6e6szk
Go to the folder find a tutorial how to setup MCPC forge server's
Set it up
Use a method to get the folder on your RPi.
Launch Up putty again.
Steps to do everytime when you wanna launch the server
1.Open the folder using the cmd 'cd'
2.Last CMD 'java -Xmx256M -Xms256M -jar Nameofmcforgejar.jar'
Note:Replace Nameofmcforgejar.jar with the name of the jar of forge you have. eg:
forge-1.7.2-10.12.2.1121-universal.jar..
Well have fun !!!
Recommendation: Overclock to 900Mhz for better performance...
About This Instructable
517views
8favorites
License:
Bio: I'm just an fellow coder..
More by DhruvMC:PineCraft - Pi based MCPC sever TouchWire
Add instructable to:
