At some point last semester I realized that ping pong balls make great diffusers and look really cool when they are glowing. Next we concluded that a hundred glowing ping pong balls would look even cooler. It was at about this point I decided that my apartment was in dire need of some ping pong ball lights.
In this instructable I'll show you a quick way to turn an ordinary string of Christmas lights into a great party decoration.
Step 1: Gather Materials
For this Instructable you'll need a few things.
Parts:
  • A string of Christmas lights
  • A ping pong ball for each light on the string
Tools:
  • Drill and drill bit (or other implement to make a hole in a ping pong ball)
  • Hot glue and glue gun
When researching this project I found that you can get a gross(144) of ping pong balls for under $20 including shipping on eBay.
Make sure the string of lights you use is in good condition. Check for any electrical shorts or overheating bulbs before starting.
Step 2: Prepare the Ping Pong Balls
Drill a hole in each ping pong ball.
There are several ways to do this such as a drill, exacto knife, or by poking a hole in it with a nail. A nail is the quickest method, but you will need to spend more time later gluing the balls to the lights. With a clean hole just smaller than the bulb the ping pong ball will stay in place without needing glue.
To drill the hole in the ball you will need a drill bit that is slightly smaller than the Christmas light bulb. Approximately 3/16" should be good, but make sure to test fit a few before drilling the rest of the balls. You will need to prepare as many ping pong balls as you have lights, if it's a long string it probably has 100.
A quick note on drilling holes in ping pong balls:
The best method I found for putting holes in the ping pong balls uses a c-clamp, some paper towels, and a drill. First fold a 1.5" wide strip of paper towel over on itself several times so that it fits on the plates of the c-clamp and tape one on each side of the clamp. Next adjust the clamp so that it holds the ball just enough that it doesn't slip when you drill into it. Because of the give in the paper towel you can pull the ball out and press another one in without needing to readjust the clamp. If anyone finds a better method please share in the comments.
I found I got the cleanest hole by first pressing the bit against the ball so it depressed slightly, then running the drill at medium to high speed while applying light pressure. A drill press would be very helpful at this step, but is not necessary. As always, please exercise care when using power tools.
Step 3: Building the lights
Slide a ping pong ball over each light.
If the holes are too loose or you choose to use a nail to puncture holes, run a small bead of hot glue around where the base of the light meets the ping pong ball. If the holes are tight enough that they won't be easily knocked off, you can leave the ping pong balls press fit without a problem.
Step 4: Hang the Lights
All that's left to do now is to hang up your new set of ping pong ball lights and enjoy.
1-40 of 131Next »
random123outburst says: Nov 27, 2009. 8:37 PM
 they would be cool if they had an LED throwie in them so that you could throw them
iApple guy in reply to random123outburstApr 5, 2012. 3:54 PM
The L.E.D. Pingie!
jeff_whitmire says: Dec 4, 2009. 9:28 PM
Great project.  I saw this somewhere else and we did a bunch of orange ones for Halloween.  Very cool glow on the front porch.
For drilling, I put the balls in an egg crate and just slid it around on the drill press work surface.  Worked great and I could just throw a handful into the crate and then dump them after drilling...no need for careful handling.
shellyrae in reply to jeff_whitmireJan 18, 2012. 11:04 AM
Great idea!
zani87 says: Nov 9, 2011. 6:50 PM
Very cool project, I've done it today, for my boyfriend's birthday :) It was cca. 15-20 minutes, I bought glue pistol, but I didn't even need to use it, cutting an X shape on them hold it just as well! Thank you for the idea, and for the others too for making it easier to complete!!
rrrmanion says: May 14, 2011. 4:27 PM
if you have the equipment, you could blow-mold the ping pong balls, then just file it into proper shape or something like that. might look nicer
vincent7520 says: Jan 20, 2011. 1:11 PM
Nice !
Very nice iii… :))
applesaucemodifier says: Nov 29, 2009. 12:55 PM
DON'T try to burn holes in them, leaves a disgusting scent that lingers for days.
Dudeyowuzup in reply to applesaucemodifierJan 5, 2011. 8:41 AM
heh, sounds like you're speaking from experience ;-)
applesaucemodifier in reply to DudeyowuzupJan 5, 2011. 7:11 PM
You have no idea, the smell is like no other. At the very least don't try it inside. I feel like i lost a few days of my life every time I split one open.
komecake says: Nov 15, 2009. 11:42 PM
  Woohoo! I randomly decided I would finally do this today for my mom for her back porch. I bought LED lights instead as they are brigther and less of a fire hazard. I got them at Home Depot for $11 for a 60 strand that has 16 different functions. Excessive? Yes, but fun. :D
 I bought the ping pong balls at Wallie Mart for $8 for 36 of them and a 15 pack of golf balls with holes for $2. Obviously that's not quite enough. I need another 15 pack, but I like how it's turned out so far! :)
komecake in reply to komecakeNov 15, 2009. 11:51 PM
  I forget to mention that we also did not drill holes. We found that cutting a small "X" with an exacto knife and pushing it on was much easier to glue on and faster than drilling holes.
craziemutant in reply to komecakeSep 6, 2010. 1:16 AM
Hmm. Sounds like you made an easy I'ble into an even easier I'ble. haha. Nice. I want to do this. Don't even have a use for them. Just want to do it. Haha.
Dudeyowuzup in reply to craziemutantJan 5, 2011. 8:39 AM
yeah! I like your $2 holey golf ball idea! The holes are already there, and from the pic, I can see it makes a cool, almost disco ball effect!
alxg37 says: Dec 8, 2010. 1:09 PM
Do ping pong balls come in colors or did you paint them? You show all white ping pong balls.
Dudeyowuzup in reply to alxg37Jan 5, 2011. 8:36 AM
The cool thing is you don't have to paint them. They glow they color of the light that's inside them.
nickabc123 says: Dec 12, 2010. 10:10 AM
soldering iron to make a small hole- emphasis on small- then using a drill bit about the same size as the light (drilling in reverse). you push the light through then pull to tighten. dont even need glue.
mecenia says: Nov 3, 2010. 6:49 PM
Hi!
Your decoration with ping pong balls are so amazing!! so cute and beautiful *-*
i'll do one tomorrow and one i'll give to my friend.
Another.. i'll put in my bedroom for light in the night.
thanks for the idea and guide!
yellow2121 says: Sep 5, 2010. 3:21 PM
Don't know if this has been mentioned but this needs a big be careful warning. Most ping-pong balls are made from celluloid. Celluloid is highly flammable. Just like movie film from the 20's and 30's, touch a match to it and whoosh, even water won't put it out. Dollar store balls may be made from plastic and a safe choice, if you test by burning one watch your eyebrows.
mojo13 says: Dec 13, 2009. 4:00 PM
 Hey, I just made these! They worked out so well! thanks for th instructable!
mojo13 says: Dec 10, 2009. 11:36 AM
DasBus says: Nov 28, 2009. 9:12 PM
 I just put one of these together today, using a battery operated light set.  Looks AWESOME!!!!  Thanks for the idea!
brain_bomb says: Oct 13, 2009. 10:41 AM
 If you go as cheap as possible on the lights and balls you have an extreme fire hazard on your hands and you've spent $5 more then the store bought version.  If you do it right and buy LED lights you've spent $25 more than the store bought version.  I have to say that when an instructable costs more than the store bought option and is more dangerous than the comparable store option it's not one to do.  If you are intent on doing this, make sure to use the LEDs.  More expensive but you can leave the room for bathroom breaks and not have to worry your house will burn down.
komecake in reply to brain_bombNov 15, 2009. 11:45 PM
  LOL @ leaving the room for bathroom breaks. I agree though. And LED lights aren't $25. I got mine for $11. They had a good set for $6!!! But I wanted the ones that had 16 different blinking functions to satisfy my ADDness. Hahaha.
brain_bomb in reply to komecakeNov 16, 2009. 7:20 AM
 Sweet, the prices are going down.  I thought $25 was a little ludicrous for christmas lights.  And I absolutely know what you mean about the blinking functions.
HeidiJJJJ says: Oct 28, 2009. 6:55 PM
Use add random google eyes and use as a Halloween decoration.
aksaks says: Oct 26, 2009. 11:36 AM
Thanks for the wonderful idea.
I got 'my balls' from a Dollar store (he he he), 6 for a buck, used a power drill and selected a drill bit size such that I did not need any hot glue at all, just some twisting of the ball to push the bulb into the hole (lots of squeaking noise though). I used regular (colored) Christmas serial lights (incandescent).
Initially I was concerned about over heating and a potential fire hazard, so tested couple of them while gradually increasing the time they were on; nothing adverse happened. Now I leave them on for about 5 hrs. I use them in the patio so I am not overly concerned of a fire hazard. Also mine stays exposed to direct sunlight during day time.
PS: The seams on the ping pong balls give it an exotic look or are distracting depending on the 'eyes of the beholder'. I purposefully randomized the seams while I was drilling holes.
Since there is a great variation in the lights, ping pong balls, duration of use and location, I recommend each user to test it before leaving it on for long periods. Its better to be safe than sorry.
illdoyourdrugs says: Oct 15, 2009. 5:41 PM
Great idea. Creative, cheap and easy.
thalden says: Oct 11, 2009. 9:28 PM
Just did this. I salvaged a fully-functional 35 light string, which worked out nicely for buying a 36-pack of balls.
I reduced the risk of fire by aiming a fan at the light string. Since cellulose isn't a great insulator, this keeps the lights themselves cool as well. It also induces a swaying motion that can be quite hypnotic, in addition to making a nice sound if hung on a wall.
Remember, though: Christmas lights shouldn't be left running for long periods of time, or unattended, regardless of any modifications you may have made.
Ev in reply to thaldenOct 14, 2009. 12:12 PM
Get LED lights. Use a fraction of the old, hot incandescent bulbs, evenin the small size.
I use a string of LED holiday lights as a night light in my store room.They use so little power I never turn them off!
Ev says: Oct 14, 2009. 12:03 PM
Great idea. The "matte" finish makes them less twinkly holidaylike.
How about the seamless balls sold on e-bay? I'll try and report back.
I bought a bunch of LED holiday lights over the last few yearsafter Christmas, they're discounted 50% or more!
2kidsofmyown says: Oct 13, 2009. 4:18 PM
instead of putting the balls on the bulb you should put them on the plastic part of the light so it dosent get so hot
harvey639 says: Oct 13, 2009. 11:52 AM
OMG they r SO cool i am going t make a set for my room!!!!!!!!!!!!!!!!!!!!!
relima says: Oct 10, 2009. 10:32 PM
Hey people! please, don't do it. Ping pong balls are can easily get on fire. If it happens close to a curtain... well you don't want to die burned because you decided to save some bucks. I have had some christmas lights that would get so hot.
Please, be careful with this project. Use leds instead of conventional christmas lights!
http://lighthousepatriotjournal.files.wordpress.com/2007/04/alexandra_burned-baby.jpg
thepelton in reply to relimaOct 12, 2009. 2:10 PM
relima has a good point.  Celulose is VERY burnable.
carl87gt in reply to relimaOct 11, 2009. 8:22 PM
I think these lights look awesome . . . absolutely awesome. But relima is correct. Ping Pong balls are made of cellulose. There are tons of recipes for making nitrocellulose lacquer for making electric matches for model rockets (another hobby of mine) online. They are very flammable.
http://www.metacafe.com/watch/384023/ping_pong_inferno/
I might still make this, but I will will probably do it as a patio decoration where there are around nothing flammable. Better still, I plan to do it with leds which run incredibly cool.
Be safe!
duckythescientist in reply to relimaOct 11, 2009. 5:49 PM
I like the led idea because leds look better (In my opinion) than the incandescents.
m0nde says: Oct 12, 2009. 12:41 AM
 very nice!
cool! says: Oct 11, 2009. 9:11 PM
 Everything is better with Balls!
QuackMasterDan says: Oct 11, 2009. 5:13 PM
Neat mod, cheap, simple, easy, and looks great. These will serve nicely for lighting up my New Years LAN party.
1-40 of 131Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
