Introduction: Ping-Pong Blinky
Picture of Ping-Pong Blinky
Ok, I bought the TI MSP-EXP430G2 Dev board a while ago, and it was about time I tried it out, as always, with LEDs and Ping-Pong Balls.
It fades between the colours.
You will need:
A 2xAA batery holder, with 2 AA batteries
A 9v battery clip
A small piece of copper stripboard, just large enough to cover the back of your battery holder, but not go over it
a TI MSP430 launchpad (really cheap, get it from proto-pic in the UK,, about $4.50 straight from TI, pluss shipping)
A Ping Pong Ball
A diffused Common Cathode RGB LED
3 pin headers
a jumper
a 14 pin DIP socket
a 10K resistor
Wire
Solder
Hot GLue Sticks
Hot Glue gun
Drill with 5mm bit
Soldering Iron
Step 1: Set Up Your Development Environment + Programming the Chip
If you have never used this development board before, you will not have a development enviroment.
The code was written for MSPGCC, and uploaded with MSPDebug - this is cross platform, a quick google will land you with the downloads
The code can be easily ported to CCS or IAR, which come free from TI
You can download the source code from my GitHub repo
Just compile it (or use the .elf provided) and use mspdebug rf2500 to program the chip (not applicable for CCS or IAR)
If this is your first upload, then congratulations, you have programmed your first chip :-D
Step 2: Check You Have Everything
Picture of Check You Have Everything
Make sure you are good to go, just a pic to check your stuff against.
Step 3: Drill the Ping-Pong Ball
Picture of Drill the Ping-Pong Ball
Hold it steady against the desk (I haven in the pic, as one hand held the camera, but I did do it, honest ), and drill a 5mm hole for the LED
Step 4: Put the LED in the Hole
Picture of Put the LED in the Hole
It should just fit in, with little room to move, the lip should stop it falling in
Step 5: Glue It In
Picture of Glue It In
Turn on your hot glue gun, and wait for it to heat up, then cover the LED in glue (leave the pins though)  This will make it permanent.
Step 6: Time to Lay Out the Strip Board
Picture of Time to Lay Out the Strip Board
First we need to add the DIP socket, as seen in the picture
Step 7: Mark It for Drilling
Picture of Mark It for Drilling
We need to mark out where to drill it to break the trace. Otherwise the pins will short.
Step 8: Drill the Traces
Picture of Drill the Traces
I deliberately did some too big so that you can compare, later on you will see why they are too big. Use the smaller ones as a guide.
Step 9: Solder It In
Picture of Solder It In
Solder the joints. You can see why the holes are too big, there is not enough room for soldering, and the joints near them are messy, going round the holes, and spreading out.
Step 10: Populating It With More Components
Picture of Populating It With More Components
Add these components and wires. The 10K resistor keeps the chip from resetting, and the jumper acts as a power switch,
Step 11: Now Just Add the LED
Picture of Now Just Add the LED
Now we just place and solder the LED, making sure we get the wires the correct way round. The longest pin should be on the broken trace with the wre on it, the other three should be on traces going to the DIP socket.
Step 12: Add the Battery Holder
Picture of Add the Battery Holder
Cover the back of the battery holder with glue, and place on the stripboard. Solder the 9v clip to the wires protruding from the circuit, and clip it onto the battery holder.
Step 13: Add the Chip and Turn It on :-Dsocket
Picture of Add the Chip and Turn It on :-Dsocket
Take the MCU from the dev board and place it in the DIP socket (make sure it is the right way round, line up the notch on one of the shorter sides with that on the socket) Turn it on with a jumper, and watch it glow and change colour.
Mahmoud Alaa (author)2012-08-15
i have the same wire cutter
ynze (author)2012-08-10
a video, a video, please please a video???????????????????
Y.
DaShroom (author)ynze2012-08-10
thou asked, and it shall be given unto thee (unfortunately it will still be filmed on my phone, so look awful)
Do you mean a video of assembly, or of the thing working ??
darthgopher (author)DaShroom2012-08-11
it would be very helpful for an assembly video.
DaShroom (author)darthgopher2012-08-12
Sure, though I am currently on holiday, so you must wait until I get home and can get new parts.
ynze (author)DaShroom2012-08-12
For me a video of the thing working :-)
About This Instructable
4,341views
13favorites
License:
Bio: LEDS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
More by DaShroom:MX3 - Professional LED PanelPing-Pong BlinkyThe Much Larger Board of Many Ping-Pong Balls
Add instructable to:
