Introduction: Ping Pong Tetherball
Learn How to make this fun, time-consuming ping pong tetherball game. You will need a fret saw though.
Step 1: Cut Out Base
Your base is a circle with a diameter of about 15 cm. Cut it out with a fret saw
Step 2: Cut Out Your Racket
Cut out your racket ,it should have a diameter of about 7cm diameter. Cut it out with a fret saw.
Step 3: Cut the Wooden Dowel
Cut the wooden dowel so it about 20 cm.
Step 4: Drill a Hole in Your Base
Drill a hole in the middle of your base piece, make it however big your dowel is. Use a drill.
Step 5: Put Your Dowel in the Hole
Put your dowel in the hole, use glue or duct tape to make it stable.
Step 6: Drill a Hole in Your Dowel
Drill a small hole at the top of your dowel. Use a drill.
Step 7: Tie Your String
Put your string through the hole and tie it.
Step 8: Attach the Ping Pong Ball
Attach the ping pong ball using hot glue from a glue gun
