Pink Eraser USB Flash Drive
Step 3Free up the flash drive
The plastic case on my flash drive was easy to pull apart. Just work a fingernail between the pieces and pull it apart.
Once it's open you can behold just how tiny the real flash drive is.
15 comments
Dec 29, 2010. 11:23 AM12koolgirl says:
Can't you just put the usb in whole?
Apr 11, 2010. 8:52 AMiamaspy says:
 I cant even take apart the frame that covers the drive. D=
I have a kingston 2gb data traveller, help on taking it apart?
May 20, 2010. 5:23 AMBraisedDuck says:
ok is urs the swiveling one or d one with d cap? if its the swiveling type, take out the outer case 1st using clipper or saw. if its cap type, u should notice a hole like notch on one side. using some plyers pry it apart
Apr 26, 2008. 1:19 AMsoul_jahz_united says:
does this in any way affect the circuit board? i.e. do fragments of the rubber disrupt the flow of power on the circuit? is there anything we could cover the circuit with before inserting into the pink pearl? lol, the pink pearl, i love it
Oct 16, 2008. 1:43 AMDerin says:
no,the tracks are already covered by solder resist and the rubber wont affect the usb unless there are moving parts which i highly doubt
Jul 21, 2009. 10:44 AMzizou361 says:
I wrapped mine in 1 layer of Saran wrap just so it didnt get annoying rubber bits under the wiring. also it slides easier into a tight fitting eraser
Oct 5, 2008. 5:33 PMgeeklord says:
if your really worried, spray some plasticote on it
Jun 28, 2008. 9:42 AMpuffyfluff says:
No. The type of rubber in a pink pearl is non conductive.
Sep 4, 2008. 2:33 PMnerfer192 says:
lol...all rubber is non conductive
Sep 4, 2008. 4:40 PMpuffyfluff says:
Technically, all rubber is non conductive. But sometimes conductive materials are put in rubber to make it conductive.
Feb 5, 2010. 8:29 PMLoganeg says:
correct only pure rubber is  non-conductive
Sep 5, 2008. 4:56 PMnerfer192 says:
oh
Sep 5, 2008. 6:49 PMpuffyfluff says:
It's mainly for keypads-then they don't have to add conductive things.
Sep 5, 2008. 8:03 PMnerfer192 says:
oh like the mac keyboard?
Sep 5, 2008. 9:18 PMpuffyfluff says:
I don't know; I've never used a rubber mac keyboard. Usually they're for numbers, for things like doors.
Sep 6, 2008. 9:07 AMnerfer192 says:
oh i get it my sister gave me her build ur own phone kit and i was wondering how the rubber keypad actually typed
Nov 23, 2008. 1:29 AMmr_bandit says:
Tear apart a remote control.
The key itself is a "hollow" rubber "cap". This allows the hollow base to collapse when the key is pressed.
Think of cupping your hand, palm down, on a table. A button push is like flattening your hand onto the table.
On the bottom of the key, inside the cap (think of this as a bowl) at the base (the deepest part of the bowl) is embedded carbon. It will not be as shiny as the rubber. (If you are still thinking cupped hand, it would be in the middle of your palm.)
The PCB where the carbon will hit looks like fingers on two hands that are flat on a table with the fingers alternating or interlaced.
The carbon makes a contact between the "fingers" of both "hands". There will be some resistance (as in Ohms law) that can be measured - it goes from an open circuit to a closed circuit. The resistance doesn't really matter at some point, it is less than an infinite (open circuit) value.
And - for normal rubber, any voltage/current strong enough to make it thru a rubber insulator will jusrt fry the rubber.
Nov 23, 2008. 9:31 AMnerfer192 says:
yes i noticed those fingers....thanks for the great explaination.
Sep 6, 2008. 9:24 AMpuffyfluff says:
Yes, that might be it.
Sep 6, 2008. 10:02 AMnerfer192 says:
okay
Sep 26, 2008. 1:06 PMDBLinuxLover says:
High Voltage can make rubber conduct. Heck, high voltage can make almost anything conduct.
Sep 26, 2008. 9:17 PMpuffyfluff says:
True.
Oct 16, 2008. 1:44 AMDerin says:
seconded
Dec 8, 2008. 7:22 AMmacmccune says:
thirded
Sep 16, 2009. 2:56 PMnedyah444 says:
fouthed
Jun 15, 2010. 4:39 PMSaturn V says:
Fithified!
Nov 14, 2008. 1:28 PMred-king says:
everything can conduct electricity. just some things more than others.
Nov 14, 2008. 3:09 PMpuffyfluff says:
Exactly.
Nov 23, 2008. 12:06 PMpuffyfluff says:
Just like how everything is poisonous, but the amounts at which they are harmful are different.
May 9, 2009. 4:37 AMSpaceman Spiff says:
And everything gives off radiation
May 13, 2008. 5:56 PMjonathan95123 says:
harder than it looks... tried it and came out crappy and off set. didnt mess with my flash drive, worked perfectly.. i eventually swapped eraser with a lego car looking thing. then made a a usb fan with legos around so you could add a switch and batteries. legos work really good, but i liked the idea of eraser, got me thinking about what to mod. thanks man
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1328
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
