Introduction: DIY Pipe Floor Lamp
Picture of DIY Pipe Floor Lamp
A few weeks ago I stumbled over the pipe lamp project by frenzy and instantly wanted to build my own lamp.
Since I made a lot of desk lamps in the past, I wanted to explore new territory by building a floor lamp. The whole project involves only a few steps and took me only an hour.
WARNING: Since this project involves AC power. Please use caution when handeling AC outlet power.
Step 1: Gather All the Supplies
Bill of material:
  • You will need some heavy wood as a base for the floor lamp. I used a 20cm x 60cm piece of countertop.
  • Arbitrary pieces of galvanized pipe to build your lamp base. In my case I used 1/2 inch pipes.
  • Preserving jar with a metal screw cap.
  • Bulb socket, light bulb, wire, wall plug and some screw terminal block.
  • Fitting screws
Tools:
  • Power drill
  • Screwdriver
Step 2: Build the Lampshade
Picture of Build the Lampshade
Drill a hole into the jar cap and run the wire through it, so the bulb socket is on the inside of the preserving jar. You can now screw the light bulb in or do it in the end.
I used a LED Edison light bulb to get some warm lighting.
Step 3: Build the Floor Lamp
Picture of  Build the Floor Lamp
Center the base of the lamp on the piece of wood and mark the position of the holes. Then pre drill them, so the screws don’t damage the wood. Afterwards screw the base onto your heavy piece of wood.
Afterwards you want to lay down all the parts as you want the final product to look like. Then run the wire through every component as needed.
Lastly you can build the base of the lamp and see what the final product will look like.
Once you have it right and are comfortable with the look of it you can tighten the pipes together.
Step 4: Do the Electrical Work
Connect the wall plug and the ON/Off switch to the wire of the lamp via some terminal blocks.
Make sure, that there isn’t any short circuit in your wiring.
Step 5: Conclusion
Picture of Conclusion
I know that the instructions are not as detailed as they should be for reproduction. But I think that I will inspire you to be creative and build your floor lamp with your own style.
Some ideas for future improvements:
  • Drill two holes into the pipe, so you can place the ON/OFF switch on the side of the pipe.
  • Use some stump of a tree as base for the lamp. It will look better than the countertop.
  • Make everything waterproof so you can place the lamp outside.
Lastly it would be nice to get your Feedback. Not only because this is my second post, but more over because I want to improve this article.
  • Are there points, where you got confused?
  • Is something not clear?
Now its your turn to build your own lamp!
See you in the comments,
sincerely Langhalsdino :)
Penolopy Bulnick (author)2016-10-06
Nice :) I like different pieces of furniture made out of pipes. It has a fun look to it!
Nils1895 (author)2016-10-03
i love projects using these kind of pipes. But unfortunatly I cant find them in germany, where did you get yours?
Langhalsdino (author)Nils18952016-10-03
It took me some time as well. You have to decide for yourself if you want to pay pharmacy prices or go on a long journey to finde cheap once.
I found mine at building supply center (Hagebaumarkt)
Otherwise you can ask at your local sanitary facility store, they should carry them as well.
If you got further questions ask me directly :)
Nils1895 (author)Langhalsdino2016-10-05
Thanks so much, I really apprechiate instructable users that actually respond. Keep up the good work!
DIY Hacks and How Tos (author)2016-10-03
Cool lamp. I really like how the pipes give it a steampunk kind of look.
Thank you :)
About This Instructable
3,393views
99favorites
License:
Bio: I am currently studding computer science in Germany and love to build stuff in my spare time. Since I live in a shared apartment, I ... More »
More by Langhalsdino:DIY pipe floor lampHow to Make 3D Printing in Homes and Offices Safer, by Building an Enclosure That Filters Gases and Particulate Matter
Add instructable to:
