These lamps are functional and cheap! it cost 30 bucks to make one lamp.
GENERAL WARNING: Although this project involves very little steps it does involve AC power. Please use caution when doing projects using AC outlet power. If you are not comfortable with simple wire soldering and heat shrinking, please use caution with this project.
Remove these ads by
Signing UpStep 1Supplies
For this instructable you will need the following, note that the pipe choices can vary depending on what kind of lamp you want.
Various sizes of galvanized pipe to build your lamp base. (i used 1/2")
1 candelabra style bulb fixture (i chose this one for it's small size)
1 candelabra bulb
AC plug with in-line roll switch
Heat shrink
tools needed:
Soldering iron
is it NOT a good idea to use schedule 40 pipe for a lamp?
Schedule 40 pipe is that white thick walled plumbing pipe used for water
lines usually.
I'm just wondering if the lamp would get too hot for that,..
Or if it would not be stable enough(IE: be susceptible to tipping over too easily & causing problems that way)?
As long as the insulation covering the wires themselves is ok, you'll be fine
By the way, if you want cheap "old-timey" bulbs, go to 1000bulbs.com I got my 30w Radio bulb for $1.71 as opposed to $10+ elsewhere.
For those who haven't discovered it yet, GrandBrass.com has the best selection of lamp parts in the universe and great pricing as well. It also has groundable sockets.
I also agree that this thing really needs at least a grommet or preferably a strain relief at the bottom. Unless it NEVER moves, this has probably cut through the insulation by now.
