Pipe Loft Bed
Pipe Loft Bed
I have been daydreaming of my very own full sized loft bed since my freshman year of college (~3yrs ago). During finals week, I decided that I could have it all: a dog, vanilla bean ice cream, AND the perfect bed for a pole vaulter. Note that I was only lacking one portion of my equation for happiness. I discovered the instructables website while searching for pictures of homemade beds. This instructable is a spin-off of ladyada's Pipe Dream Bed:
http://www.instructables.com/id/Pipe-Dream-Bed/
I like that iron pipe gives an easy-to move, sturdy base material for this bed. Thumbs up, ladyada.
I used webbing to suspend my mattress/box spring in order to make the sleeping platform very swingy. If you want a more stable platform without the use of a box spring, please look at other instructables because I am only recording what I did. I haven't made a ladder for this yet and I will also be attaching a Navajo-style loom on one end. Having this tall bed creates space for reading/knitting/weaving/sewing/yoga in my room. It is also strong enough to do pull-ups and Bubkas and other strengthening exercises for pole vaulting.
Step 1Materials
Materials
3 Ratcheting straps with a high working load (1000+lbs) I think that mine are 1500lb straps.
2 lengths of webbing: 12-15ft does the trick.
1" diameter pipe is used:
for legs-
3 lengths 58"
1 length 56.5"
2 lengths 55"
for head and foot-
2 lengths 53.5"
for sides-
2 lengths 75"
couplers-
8 T's
4 L's
3 Unions* (these are used to join the pipes in a square)
7 close nipples* (Just look for an incredibly short, double-threaded length of pipe.)
2 10' lengths of cable
8 cable clamps
tools-
1 pipe wrench to tighten the joints
1 talan wrench-see pic. This is used to grab the pipe and tighten it in its socket. Very useful!
*Thanks to Wyle_E for sending me the correct names!
114 comments
1-40 of 114next »
Sep 5, 2011. 10:06 PMbatz13 says:
Just wondering how much it would be price wise to build this.
Jul 7, 2011. 8:10 PMdvnfntn says:
Would this hold someone between 250-275 lbs?
Jun 18, 2011. 8:46 AMtriumphman says:
FYI: Wood is also less expensive, all that pipe (black cost more than galv.) Black pipe is more expensive cause it is required (safety codes)here to connect gas to your hot water heater and furnace! It was discovered that galvanized leaked gas through its pores under pressure. The black for some reason does not leak. So it cost more! Go figure! Anyway wood is more estetically pleasing and you can attach many things to the posts. Pictures, hooks, hangers, nails, screws, jewelery, signs, strings, ropes, canvas, lace , skeeter netting, just to name a few. Have fun ! Be safe!
Jun 18, 2011. 8:34 AMtriumphman says:
No way! This bed will collapse if you even just roll over. You are in for some serious hurt dude! Forget about a two-up situation! I'll pass on this. The pipe & joints are too fragile! Try it out and see. I made one and it collapsed the first time I got up in it! I'm only 185 lbs. Go for the 6x6 or 8x8 wood post model, it will stand under all situations. I built one using bolts, nuts, washers. Awesome!
Mar 7, 2011. 12:31 PManfractua says:
I'm seriously thinking about making this when I move in the next couple months. About how expensive was it to make this bed?
Jan 5, 2008. 1:51 AMwatermelon says:
Yeah, and if you are going to instruct people to put oily rags in the laundry mat dryer why not go ahead and tel them to pour toxic waste into the sewer?
Mar 7, 2011. 8:15 AMXxyoung1771 says:
Please notice she said dryer not washer, i
Driers don't go to the sewage system. ;)
Jan 5, 2008. 8:17 PMuberchoob says:
wow..... someone here has a little more baggage than they should be boarding with.
Jan 5, 2008. 10:31 AMWeissensteinburg says:
Do you see the "jk" after it? That means "Just Kidding"
Mar 5, 2010. 11:30 AMGalateaofTor says:
I believe you meant "discard" instead of "disregard".
Feb 11, 2011. 12:15 AMgeckoLove says:
Disregard as in "ignore the short pieces you see in the photo that were not called for in the materials list"
Jan 2, 2011. 12:36 AMcatchphrase says:
I've been doing a mockup in Illustrator, but then realized I was drawing a part that I wasn't sure existed or was readily available. It's a fitting that connects 4 ends together but not a cross fitting. Looks like a seesaw molecule:
http://www.askthetachemistryhelp.com/image-files/seesaw.gif
Has anyone seen a fitting that looks like this? If not I suppose stagged t-pipe fittings at alternating angles along the main axis would work. Or perhaps a 'slip on pipe fitting'.
Also, it looks like the larger diameter fitting that could be useful for feet of the pipes is called a 'pipe offset' though I'm having trouble verifying that online at local store websites.
Also, stumbled across this wild looking thing:
http://www.habiter-autrement.org/08.minimaliste/im-08/urbannomadics-livingscaffold.jpg
Thanks for the Instructable! Got me thinking about how to construct my own version. :)
Oct 14, 2010. 4:54 PMmista.v says:
How much did all the piping cost?
Sep 21, 2010. 6:15 PMraith2006 says:
ok i'll bite. Why a loom?
Sep 20, 2010. 11:22 PMmae-kitty says:
LoL forget using a mattress, i would just use straps the whole length of the bed and sleep on that xD. It seem funner. AWESOME bed BTW
Jan 5, 2008. 7:45 PMbunycraft says:
Looks like way fun... I would want more straps though. Not willing to live that close to the wild side, lol. I always wanted a loft bed.
Oct 21, 2008. 11:50 AMjeff-o says:
Do you even need the box spring, I wonder? It seems to me that its main purpose here it to prevent the webbing from digging into the mattress - a task that could be done equally well with a layer of plywood. By removing the height of the box spring you'd also get a bit more headroom.
Oct 23, 2008. 9:34 AMjeff-o says:
Oh, definitely use what you have first!
Sep 14, 2010. 6:49 PMmysss says:
Thanks for clarifying--that's important to note if you don't have a box spring! (i.e., if you're using a college-provided bed)
Sep 13, 2010. 3:55 PMCharlie13 says:
how difficult is it to unscrew these cables. this bed seems ideal for the college dorm but i was wondering when i need to move every year
Sep 8, 2010. 6:05 PMTFElite says:
Just wondering, but how much wight can this hold? I'm 6'2, and a bit on the bulky side, but this is a great idea, 'cause my room isn't too big, and my bed currently takes up at least half of my bed. I'd just like a bit of more room.
Sep 4, 2010. 9:25 PMtheMoot says:
i have the exact same star wars sheets!
Mar 5, 2009. 8:25 PMitstemo1 says:
I might make this. But I will probably do some Mechanic of Material deformation drawing before placing my weight on it. I might need hard thicker piping
Mar 5, 2009. 7:02 PMFretka says:
how easy is it to get into and out of? AND does it move a lot or is it pretty stable? I love this idea !!!
Jan 9, 2009. 4:32 PM8bit says:
So, you know, a bed can be a very active place sometimes. Will this design handle the rigours of athletic activity, like . . . wrestling?
Oct 21, 2008. 11:14 AMEmDiz says:
Question for you - why did one of the legs have to be shorter than the rest? I'm thinking about setting this up, but want to measure a bunch cut once. Thanks
Oct 9, 2008. 2:51 PMDorkfish92 says:
Here is mine! I couldn't wait any longer, so last night I threw the air mattress that I've been sleeping on onto the pipe bed. Surprisingly, it did not fold in half and I slept rather well. Any ways, I got my real mattress today. Yay!
Finished with mattress
With air mattress
Oct 11, 2008. 11:27 AMDorkfish92 says:
Thanks! Just to let anyone else know, the "swing" wasn't as much as suspected. It's more of a "sway" and it's just while getting onto the bed. One more thing, if you use an alarm clock, don't do like me and leave it on the other side of the room. It's pretty hard to jump down from this bed when you first wake up (didn't turn out so good for me)
Sep 21, 2008. 6:40 PMDorkfish92 says:
Building mine this week! I'm using galvanized steel because all the local black iron pipe is VERY rusted. I'm also making it a twin so it will fit in my new room. I'll should have pictures posted by this weekend if it's finished.
Sep 30, 2008. 2:22 PMDorkfish92 says:
I didn't document it while i built it, so I can't make an Ible. Maybe I can send you pictures and you add them to the end of yours? Or I'll make a slide show. I just put a rope ladder at the end of it and finished the reinforcement with 3/16 in. cable. I'll send pictures when I get a mattress put it. Thanks for the Instructable!
Oct 1, 2008. 1:29 PMDorkfish92 says:
Cool. I'll make one as soon as I get a camera. I'll add a link to this Ible in the slide show.
Sep 26, 2008. 3:21 PMDorkfish92 says:
You may want to specify what length the closed nipples are. I was at Lowes buying my supplies and they had lengths from 3-7 inches. I bought 3 in. I hope they work! I'm starting building mine tonight.
Sep 30, 2008. 2:23 PMDorkfish92 says:
Yeah, I went back and replaced them with the small nipple pieces. They had them at Home Depot but not Lowes.Now the bed is even ( it was crooked with the 3 in.)
Jan 20, 2008. 9:49 AMphoenix124 says:
great instructable... i've been thinking about building a PVC loft bed... it'd be light and easy to move and since i'm going to be moving into an apartment in college soon, thats kinda important to me. equally important though, is not falling 4 feet through the air in the middle of the night. do you think it'd work, if i used a truss system for extra support? if i ever get a working bed, i'll totally make an instructable :)
1-40 of 114next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:nerdologist
I like to sew, knit, invent, read, play old school video games, eat vanilla bean ice cream, make my dog pull me places on my shlongboard, pole vault, work on my vintage vehicles, hike or bike, camp, h...
more »
