3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pipeski's Wallet SD Holder
Step 4Adding the back panel
Cover one side of the foam insert with craft glue. Try to use as thin a coat as you can. Make sure you glue right up to the edges.
Place the foam insert onto one of the cards. Press down hard to get a good adhesion, and wipe away any excess glue.
Slot in some SD cards to ensure that they fit perfectly. Slide the four 'prongs' of the foam to the left or the right while the glue is still a little sticky to make adjustments. This is an important step - if you miss it out you could find later that one card is loose and another is too tight.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pipeski
