Step 5Glue it Up
Use a piece of pipe to help align the barrel slot and stack the layers on it. I added some wieght to the top and let the glue cure for a couple of days.
After I double checked that the layers were bonded, I cut the slot for the firing mechanism, which I should have done before the glue was applied. You won't make the same mistake.
To shape the cannon, I left the foam on the pipe and sanded with 60 then 140 grit sand paper.
The next layer was "Foam Coat" a commercial product that worked well, but in the future I would fiberglass the foam if the project would see a lot of use (like this cannon). For a prop that didn't need to be too durable I probably coat the exterior with plaster of paris or something similar.
Because the foam is coated, any paint will work. Use a latex based paint if it contacts the foam directly or it will melt your project.
Add Comment
