3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pirate Cannon - A working replica of a naval cannon that fires pneumatically
Step 6Fire in the Hole
Fire in the Hole
The firing mechanism is in order from right to left:
1/4 inch quick release
1/4 inch to 3/4 inch fitting
Sprinkler Valve (3/4 inch inline modified) Tutorial Here
3/4 inch close nipple
3/4 inch to 1.5 inch flush bushing (schedule 40 PVC)
Schedule 40 1.5 inch coupler
Schedlue 40 pipe 1.5 inch cut to length (the barrel)
During the modification of the sprinkler valve, you will add a 1/4 inch threaded nipple, and to this I attatched a lenght of hose and then the "blow gun". The blow gun acts as the trigger for firing the cannon. The quick disconnect is connected to the hose that runs to the compressor.
5 comments
Oct 23, 2008. 5:41 AMkdiver58 says:
What is the section of tube that comes out the top of the valve used for? I'm talking about the piece that has the red end .. Thanks K
Oct 8, 2008. 4:54 PMstewey says:
I am having a problem with air leaking out of the barrel..When I put my finger over the spot where the solenoid is the leak goes away..Do I need to seal that hole where the solenoid goes with a little JB Weld?
Aug 7, 2007. 8:36 PMCaptn Avenger says:
Instead of modifying the irrigation valve, you could trip the solenoid with a 9 volt battery. That is how we (irrigation service technicians) test them in the field.
Jul 14, 2008. 8:39 PMmaxpower49 says:
how much was the fiberglass and how did you make the reuseable glowstick round
May 19, 2008. 12:58 PMootm says:
COOL!!! I think you need a video.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Part Time Chef.com
Proud Dad, Pyrotechnician Licensed in Ohio, Corporate Chef, Artist, Writer
