3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Piston Marble Pump
Piston Marble Pump
This is a piston marble pump i made for my marble machine after seeing
http://www.youtube.com/watch?v=0Fg3SkLm0o8
It takes 5/8 inch marbles.
The reason I like this pump design is because it doesn't let the marbles clack together when there are no marbles in the feeder. It is also less likely to jam then a previous model I built.
---Update---
Added a picture of the pump installed in the dragon marble reservoir.
The marbles enter through a hole between the feet and tail and exit through the mouth.
The dragon was already made, so I had to fit the new pump underneath as best I could.
http://www.instructables.com/file/FYAHUUCFZWXOVBY/?size=SMALL
7 comments
Aug 25, 2010. 4:23 PMJynx. says:
Do you manually put the marbles back in?
Oct 5, 2009. 7:48 AMOctan says:
How do you prevent backflow?
Oct 21, 2009. 6:09 PMOctan says:
Thanks!
I'm trying to "translate" your pump to Plastic elctrical piping, w/o much success..... I used a 3" hinge as backstop.
I think I'll be less independent, and just copy your system, or maybe make an elevator out of a cross-cut of an old tyre innner tube? (glue U-shaped blocks of wood to the outside with anaerobic glue to lift the marbles )
Sep 23, 2009. 4:23 AMskimmo says:
what does it do?
Sep 27, 2009. 5:04 AMskimmo says:
its seems super pointless
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:OldVamp
