Pizza Box Solar Oven
Published
Introduction: Pizza Box Solar Oven
Here are two images of what your solar oven should look like before and after.
Step 1: Grab All Your Materials
The materials that you need in order to make the solar oven are:
-a pizza box
-box cutter
-tape
-scissors (to cut paper)
-aluminum foil
-saran wrap
-black paper
Step 2: Cut a Flap at the Top of the Box
With the box cutter cut a square of the top of the box. Make sure you do not cut the whole thing off ,but instead make a flap on top.
Step 3: Place Aluminum Foil on the Bottom of the Pizza Box
At the bottom of the box place Aluminum foil at the base and the sides of the bottom half of the box. To make sure it does not get moved tape it down.
Step 4: Place a Piece of Paper on the Base
Cut a piece of black paper with the dimension of the base of the pizza box. In order to make sure it stays on ,like the aluminum foil, tape it on.
Step 5: Put Aluminum Foil on the Flap
Put aluminum foil on the inside of the flap and tape it on.
Step 6: Saran Wrap
What you have to do next is to put the saran wrap on the part of the box that is cut out, so that the solar rays can go through it and be absorbed to heat whatever is inside the solar oven.
Step 7: You're Done!
Enjoy your new Solar Oven.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    So wait....does this come with insurance from Allstate or Farmers?????????
    Nice! How long does this take to cook? Have you cooked anything in it yet?
