3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pizza Box iPad Stand
Step 4Cut out the pieces
Cut out the pieces
There are two main pieces, the stand itself (the big one) and the crossbar (the smaller rectangle).
If you have one, use a paper cutter to cut along the main lines.  After that, use some scissors to cut out the curvy parts on the main stand.  I made several relief cuts to make it easier to get at the inside corners.  Use your best judgement.
Since those inside corners are going to be covered by the crossbar, it's not super-important to get them perfect.  If things aren't fitting later on, you can clean them up more as you need to.
For the crossbar, leave the small slits for later, those require some special fitting later on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ftPeter
