Introduction: 'Pizza' the Photokinetic MothBot
Pizza is a photo-kinetic robot and is a biomimicry (and inspired by) of the photoreceptor and photomovement of microorganism.
Many freely mobile microorganism are capable of changing speed based on light intensity in a random direction. Their motor receptors are entwined with the illumination of the environment through photoreceptors.
This is simulated by the robot, 'Pizza' through random directional changes every 100 seconds. Net result is a robot that welcomes light, which can be found by taking the gradient of the overall movement based on lighting levels. In this case, it moves faster as the lighting levels increases, therefore Pizza the robot welcomes light.
For more information about the photomovement of microorganisms, here's an interesting research paper
http://pubs.rsc.org/en/content/articlelanding/2002...
Step 1: Tools and Materials
Hardware
- Foam board
- Swivel-Type Castor Wheel
Electronics
- Arduino
- Photoresistor
- 2x DC motors
- L293DNE Motor Driver
- Breadboard
- Battery holder
- 4x AA batteries
Tools
- Glue gun and glue sticks
- X-acto blade
Step 2: Cut the Foam Board
Cut the foam board to a pizza-slice-shaped leaving enough room for the motor, battery, arduino, and breadboard to be mounted.
Step 3: Glue the Motor and Wheels
Glue the motors to the back side of the foam board on both corners of the 'pizza slice.'
Glue the 2" castor wheel at the front of the foam board.
Once dry fit the motor wheels snuggly on to the the shaft.
Step 4: Gluing the Electronics
Glue the battery holder at the very front or tip of the robot, followed by the Arduino, then the breadboard at the rear end. You may glue or tape Arduino or breadboard.
Step 5: Circuit: Connecting the VCC
Connect pin 1, 8, 9, and 16 all to a common voltage source, VCC, on the red power rail of the breadboard.
Step 6: Circuit: Connect the Common Ground
Connect pins 4, 5, 12, and 13 all to a common ground to the blue breadboard rail. Then connect the red rail to 5V and blue rail to GND on the Arduino with jumper wires.
Step 7: Circuit: Connecting the Signal Pins
Connect the first motor to pins 3 and 6. And connect the second motor to pins 11 and 14.
Connect the pins 2, 7, 10, and 15 to pins 3, 5, 6, and 9 on the Arduino board.
Step 8: Circuit: Wiring the Photoresistor
Connect the photoresistor to a female-male jumper wire and glue it to the battery holder upright.
Connect one of the leads to a 10kΩ resistor in series to VCC. Connect this same lead to A0 on the Arduino board.
Connect the other lead of the photoresists to ground.
Step 9: Upload the Code and Test Run
//L293D
//Motor A const int motorPin1 = 3; // Pin 14 of L293 const int motorPin2 = 5; // Pin 10 of L293 //Motor B const int motorPin3 = 6; // Pin 7 of L293 const int motorPin4 = 7; // Pin 2 of L293
const int speedPin = 9;
//This will run only one time. void setup(){ //Set pins as outputs pinMode(motorPin1, OUTPUT); pinMode(motorPin2, OUTPUT); pinMode(motorPin3, OUTPUT); pinMode(motorPin4, OUTPUT); pinMode (speedPin, OUTPUT); pinMode (A0, INPUT); }
void loop(){
int light = analogRead (A0); light = map (light, 0, 1024, 0, 255);
int num = random (1,4); if (num == 1){ forward(255); } else if (num == 2){ left(255); } else if (num == 3){ right(255); } else if (num == 4){ reverse(255); } delay(100); }
void left(int speed1){ analogWrite (speedPin, speed1); //This code will turn Motor A clockwise digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); //This code will turn Motor B counter-clockwise digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH); }
void right (int speed1){ analogWrite (speedPin, speed1);
//This code will turn Motor A counter-clockwise digitalWrite(motorPin1, LOW); analogWrite(motorPin2, speed1); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); //This code will turn Motor B clockwise digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); analogWrite(motorPin3, speed1); digitalWrite(motorPin4, LOW); }
void forward (int speed1){ analogWrite (speedPin, speed1);
//motor A clockwise digitalWrite(motorPin1, HIGH); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); // motor B clockwise digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, HIGH); digitalWrite(motorPin4, LOW); }
void reverse (int speed1){ analogWrite (speedPin, speed1); //motor a clockwise digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, HIGH); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, LOW); //motor b counter clockwise digitalWrite(motorPin1, LOW); digitalWrite(motorPin2, LOW); digitalWrite(motorPin3, LOW); digitalWrite(motorPin4, HIGH); }
Makerspace Contest 2017
