PizzaPro- $50 Brick Oven Pizza Grill
 by imadami
FeaturedContest Winner
Want to be able to make your own delicious brick oven pizza at home but don't want to invest the hundreds of dollars and precious backyard space to make a traditional pizza oven? Make the PizzaPro for only fifty dollars and a few hours of time. The pizza pro is a modified BBQPro charcoal grill that can easily be made in an afternoon. Its is inspired by the FrankenWeber grill by pizzahacker
After moving from New York City to Springfield Missouri I was extremely disappointed to find out that pizza in the Midwest is either cracker thin or an actual tomato pie with sauce and meat thrown in. So I started to make my own NY style pizza and found it to be delicious and pretty easy. During the summer though turning the oven on heats up the whole house and makes it a hassle to cook. The easiest solution to this is to make your own outdoor pizza oven! Read on for the details of how I built mine.
Step 1: Get your supplies and assemble the grill
Required Items:
A Charcoal BBQPro Grill $27 at Kmart
8 Fire Bricks ~$13 check your local hardware store or stone lot.
Metal Hangers
Furnace Cement ~$5 at Ace Hardware
A pizza Stone or Unglazed Terra Cotta tile ~$2
Grand total: 47ish dollars
Tools Needed:
Drill
Masonry drill bits
Hammer and Chisel
Putty Knife
Metal Snips to cut the Hangers
Once you have the needed supplies you can assemble the grill according to the instructions and start working on converting it to the PizzaPro. The first step in the conversion is to remove the hinges that hold the top of the grill onto the base. Then you need to move the handles from the front of the grill to the top so that you can lift the lid on and of easily. I used the same screws and handles that came with the grill and just drilled new holes in the top.
jamilks says: Sep 12, 2011. 11:38 PM
Imadami, aloha from the Big Island~ Thanks for sharing this instructable! It inspires me to go ahead and insulate my grill as I'd initially intended. I just wasn't sure how to hold the brick pieces in place but seeing how easily you drill through them makes me think that I can do the same sort of thing. The other thing that I might try is making some sort of matrix on the inside sides of my BBQ and packing it with furnace cement, although I'd have to check and see if such a thing is sold in Hawaii...not too much call for furnaces...heh heh...Anyway, thanks again for sharing your ideas and enjoy your pizzas!
Ronyon says: Sep 10, 2011. 8:52 AM
Very improvisational! What temperatures are you getting?
Have the metal hangers held up?
Have you tried firing it w/wood?
I cant believe you haven't gotten more comments on this great 'ible...
Gomi Romi says: Sep 5, 2011. 11:50 PM
Excellent idea! Were you able to measure the temperatures in your 'pizza oven' ?
macrumpton says: Apr 29, 2011. 9:15 PM
I was thinking of doing a similar thing with two cheap round charcoal grills (the kind you can get for about $7 in the supermarket). One grill would be the bottom and I would use the other for the lid. One cheap round pizza stone could be used for the cooking surface and another one could be fit inside the lid for the heat absorber/radiator.
I wonder if using some metal might be even more effective than using stone/brick for the lid, after all metal absorbs and radiates heat far better than stone. The downside is that it would be heavy.
One last thought is that adding some kind of insulation on the lid of your oven might be good to prevent losing so much heat.
johnnyblegs says: Sep 11, 2010. 5:18 PM
Your instructable makes me want to accessorize my barrel bbq instructable to make it more pizza friendly. I LOVE grilled pizzas!
ariannest says: Sep 7, 2010. 11:21 AM
Super cool!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
