Plant Watering Warning
905
21
4
Posted
Introduction: Plant Watering Warning
a super simple circuit for plants
Step 1: Part List
  • a PNP transistor (i use CBF493S)
  • a N-channel mosfet (i use 4800BDY)
  • a trimmer 100k
  • resistor 10k
  • resistor 1k
  • a led (i use a flash led)
  • small battery 3.6v
  • 2 stainless steel probes
Step 2: Circuit Diagram
you can use most of pnp transistor and N-channel mosfet..
you can adjust the sensitivity with the trimmer
Step 3: Print the Pcb
print the pcb, or make yours for the parts you have
Step 4: Solder the Parts
add a 3 pin connector for the battery
Step 5: Build It
place the probes on a plastic with hot glue
place the pcb
  • you can add a test switch between the probes
  • add a nice box for the circuit
  • you can recharge the battery (i dont know when)
Step 6: End
when the plan need water the led flashing (if you use flashing led)
--you must adjust the trimmer--
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    3 Comments
    Good job, Just a few questions, Your transistor, stainless steel probes i cant seem to find one online would you perhaps be able to send me a link?
    Why dont you consider adding in a mini solar panel?
    Thanks
    yes...! but i must to see how it will go in the future!
