Planting an Earth Box
I planted my Earthbox on my balcony with six different herbs and vegetables.
One of the Neighbors Project ideas is to "Plant your windows, porch/stoop/balcony or other publicly viewable space with plants and flowers." I've taken that advice by setting up a mini garden on my balcony, including this Earthbox that my mother gave me last year.
The instructions in the box for setting it up are idiot proof, but there are a few other things I wanted to add to them to help people make the most out of the project.
Step 1Assemble the materials
To plant an Earthbox, you need:
1. An earthbox - My mother gave me one as a gift, but you can order one online at www.earthbox.com/.
2. Plants - Look for your local nursery and spends some time wandering around looking for things you'll either want to see and smell or eat frequently. I had plants forced on to me last summer and ended up really enjoying growing my own herbs and vegetables in particular so I looked for edibles at one of the many independent plant stores in my neighborhood. I bought lemon verbana, sweet basil, purple basil, tomatilla, arugula and tarragon from a nursery a few blocks from my home. I believe that you can plant up to eight items in the box, and you're encouraged to plant edible items. I have a large basket on my bike so I biked all of the seedling plants home, which I have to admit greatly added to the fun of the project.
As I discovered in the process, you'll probably also need:
3. Measuring cup
4. Ruler
5. Scissors or knife
6. Plastic bags
7. A big tub or bucket
8. A small plastic dish with walls
9. A tea kettle or watering can
28 comments
Nov 25, 2011. 5:37 AMtim_n says:
To make your own 'earth box'
Take a large tub with no holes in. Add some standard household bricks to the bottom and lay over it a mesh of either plastic (old veg transport boxes from the grocer have a plastic mesh similar to the above!) or metal.
Cut two holes in the side, add a length of tubing. Follow instructions on this 'ible.
Drill a hole in the side at the same level of the mesh to drain if you over fill.
It won't be so pretty, but will still grow the same veg. Probably cheaper too.
Good 'ible though :)
May 8, 2008. 5:21 AMwilson.joe says:
Miracle grow contains metals which are not good to take into the body, also traces of arsenic and other deadly chemicals..
Jul 9, 2008. 9:17 AMbiochemtronics says:
OMG - regular dirt and soil also contain metals, salts, arsenic, and other deadly (in large doses) chemicals. Hey, even water is toxic in large doses. Miracle Grow is a fertilizer. Any fertilizer would be toxic if you ate or drank it. Don't worry about it. It is not going to poison you through your plants. I am amazed at some of the off-the-wall completely baseless warnings some people post.
Nov 25, 2011. 5:33 AMtim_n says:
UK wise we have two different types of miracle grow - one says 'not for vegetable plants' and one for vegetable plants.
I suspect that's because of the balance of chemicals not because it breeds deadly veg. Though to be honest, I'd probably think that if I picked up the bottle. They're both priced at the same amount.
However, you can use comfrey bocking 14, nettles, seaweed or even horse manure in water to make a "tea" to water your plants with (this can all be 'free'). Personally, I wouldn't drink any of that either as it essentially involves the leaves/manure rotting down :) But then again I've never considered drinking miracle grow either...
Jun 26, 2007. 6:44 AMdijital101 says:
Uhm, actually miracle grow is toxic. It's main ingredients are nitrogen and phosphate which are toxic. They can call it "vitamins" all they want but it is still just plain old agricultural fertilizer. If you are worried about environmental impact then you really shouldn't use it or other otc fertilizers. In small amounts (like when people use it on their gardens) it is fairly harmless, but in large quantities it can be detrimental to biological ecosystems especially on aquatic life.
May 15, 2009. 11:58 AMmcubebrooklyn says:
Well it's toxic to humans and pets, if they eat it directly. But plants need nitrogen, phosphorus, and potassium (NPK) to live; they use them to run the chemical processes that result in tasty vegetables. The NPK compounds themselves are consumed and do not end up in the produce in their original, bad-for-humans form. As for environmental effects, the main concern from agricultural / garden / lawn runoff is actually an excess of nutrients, which causes huge blooms of algae, which consume all the oxygen, which makes everything else in the lake/stream/ocean suffocate and causes a dead zone. This is a serious (and growing) environmental problem, but the fertilizer itself is not killing the fish. All that said, I would be hesitant to use Miracle-Gro or other fertilizers, even in a container garden, because (a) it's usually not necessary, especially if you're starting with commercial potting soil, and (b) everything ends up downstream eventually and I do not want to contribute to the dead zone problem.
Jun 17, 2007. 9:32 PM!Andrew_Modder! says:
use miracle grow! i planted strawberrys last year and this year it bloomed to 5 plants!!!!! :-) cool instructable.
Aug 27, 2008. 11:41 PMA good name says:
Miracle Grow is not toxic. It is however, non-organic. Try better alternatives... I use teabags personally, but I've heard that SMALL amounts of Ash are good for your garden.
Mar 4, 2009. 5:49 AMSlezridr says:
A good name and others: For container planting, miracle grow is fine. The concern about commercial, chemical fertilizers is when it is used in garden soil. The chemicals are detrimental to the beneficial organisms, worms that give life to your soil. I'm a small time organic gardener and refuse to use commercial fertilizer in anything other than container plants, even then, I prefer organic as the potting mix will eventually wind up in the soil somewhere. Just my 2c.
Aug 27, 2008. 5:41 PMthenear1send says:
Miracle grow and other chemical fertilizer have lead people to belive they are poisonous, and that is true in the case that if you are drinking the miracle grow yourself. The idea that it is "bad" to use chemical fertilizers on plants is totally ridiculous. People (including the pro-organic, and other hippies alike) think using primitive anecdotal logic spoon fed to them by the media and start to believe that "if its poisonous to me, and if i feed these chemicals to my plants, then i will be growing poisonous vegetables!" But what they don't know, is that plants are "chemical factories" which convert and metabolize chemicals such as, potassium nitrate, urea, phosphoric acid, and ammoniacal nitrogen into nutrients. The most commonly advertised primary ingredients in these chemical fertilizers are (N) Nitrogen, (P) Phosphorous, and (K) Potassium include some of the nutrients that are derived from the "toxic chemicals" which you "should avoid" applying to your plants. So fertilizers are perfectly safe, and dont let any hippie or Whole Foods/ Trader Joe's tell you otherwise, because they got their information from some unreliable source, such as the news television. As for plants, and as andrew_modder says, "O.D. them on vitamins". Plants don't "need" fertilizers. Plants usually only need fertilizers on the instance that they are malnourished (same for the people variety of vitamins). You can't make an Arnold Schwarzenegger super-plant by pumping it up on Miracle "Juice", but you can sickly deform and kill plants with excess chemicals, and NOT for the reason that they have "concentrated salts" in them as lucianoabcd says, that's total nonsense. The over application of various halides, such as: fluoride (F−), chloride (Cl−), bromide (Br−), iodide (I−) and astatide (At−) is not killing your plants. You would kill them by similar reasons consuming an entire bottle of those tasty candy-like children multivitamins would kill you. There is a balance in plants, they have a specific need and over indulging their need can kill them, same goes for under treating their need (of nutrients). Well I hope that will help you and your questions twords miraclegrows "toxicity"...
Aug 4, 2009. 7:31 AMserpensphile says:
Yeah...that's why Scotts sells like a million tons of it annually and everyone is dropping dead because they are eating "contaminated " vegetables. LOL
Aug 27, 2008. 6:15 PMthenear1send says:
In response to the part on salts.. Potential anions (negatively charged ions) do include nitrogen, phosphate, and sulfates and potential cations (positively charged ions) do include ammonium, calcium, iron, magnesium, and potassium. Which are all common in fertilizers to create salts. I was mistaken on the definition of a "salt" and thought they primarily consisted of the halides... Well Sorry on that! You can have overly salty soil (in addition to nutrient over dosing with fertilizers). Seems too much of a good thing is almost always bad...
Jun 19, 2007. 12:38 PM!Andrew_Modder! says:
toxic!???????!? whered you here that!!?! no miracle grow is plant vitamins, it makes your plants thrive and grow strong. lol theres nothing bad about it just you can only feed your plants m.grow 1ce a week, or it will O.D. them on vitamins. :-)
Aug 7, 2008. 2:39 PMnerdologist says:
You can also make your plants bionic if you shine them with a lot of red light (lessons learned in apartment gardening).
Jun 19, 2007. 7:51 PM!Andrew_Modder! says:
lol, yeah i O.D.'d a bamboo plant cause i didnt read it could kill it and the next day it turned from Green to white-brown. :-( i had to throw it away and it has been alive for 3 years :-(
Oct 14, 2007. 6:17 AMlucianoabcd says:
I don't know if this comment will arrive to all of you or just to the last person of the comments chain, but let me contribute with this: !Andrew: These "nutrients" consist mainly of salts which are very concentrated, so you should be very careful about the amount you use. Even if your plant is resistant to some of the strange metal ions contained, you may just cause a salting shock! About the strawberries, well, I have strawberry plants and each of them gives 2 or 3 new plants every summer, even if I don't feed them with nutrients. May be your giving them nutrients made them multiply more than usual, but remember, strawberry plants are very prone to asexual reproduction. General: I red a comment above talking about the impact of fertilizers on the environment; well, I agree with dijital101 on this, and I think that, at the level of growing plants at home, there's no need for using fertilizers. Besides, it can really become an issue if you extract the water you drink from underground with a pump. As for eating fruits grown with fertilizers, I don't think there may be problems as the concentration of salts and ions in the fruit are controlled by the plant. Happy gardening!
Oct 25, 2007. 5:28 PMfusion girl says:
Hello there, i dont know if im doing this the write way but i was wondering if fertilizers cause insects or mite? I have a small garden in my balcony with lettuce, herbs like sage, etc. and ive got these little green flies on them or white spots and it seems to have gotten this way after i used a dead fish fertilizer..help!!
Aug 7, 2008. 2:41 PMnerdologist says:
Maybe some soapy water spray will help you get rid of your plant bugs. It usually works with aphids.
Mar 20, 2008. 6:33 PMnaught101 says:
Have a read ecosystems somewhere. Any biosystem which has a limited diversity, and a large energy, water, and nutrient input will eventually grow weed species (the straw berries in this case), and once those species start to flourish, they will become a great target for pests. This is the monoculture effect. So basically, yes, if your fertilise too much for one plant type, you're gonna get pests. It's not the fertiliser that attracts them, it's the abundance of a single type of pest food. It regards to the fish fertiliser, it might be that it's too concentrated in a specific nutrient - plants, like animals, need a balanced diet, and unhealthy plants (like unhealthy animals) tend to get attacked more by predators. You should also think about the impact of using fish, since about 75% of world fish stocks are over-exploited, and 90% of large-fish stocks have disappeared (New Internationalist).
Oct 26, 2007. 12:58 PM!Andrew_Modder! says:
:-\ stuff like miracle grow will not, but yeah dead fish would :-X eeyuck! :-P
Oct 14, 2007. 10:17 AM!Andrew_Modder! says:
:-\ about the bamboo, it wasnt the powder stuff, it was the liquid, witch i believe doesnt have really any salt in it, but still its got iron and crap in it and i understand now that it kills lol :-(
Feb 8, 2008. 6:19 AMhitokiri_808 says:
Nice tutorial. I was debating about buying an earthbox and I wanted some good pictures of the earthboxes besides the stock ones on their site and amazon. The construction looks pretty good, I think I might buy one and try it out before trying to make one. The earthbox isn't all that expensive anyway.
Aug 9, 2007. 8:18 PMemeraldgreen says:
seaweed fertiliser is good, smells a bit though.
Jun 26, 2007. 4:09 AMWeallliveintheyellowsubmarine says:
Very nice
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:neighborsproject
