Plants vs zombies coin bank from recycled toys
 by mygibzone
Featured
Step 5: LETS GIVE IT SOME CURVES
*It's time to work with our clay now that our skeleton is constructed and stable. First round out the mega blocks so that they look like shoes.
*Then construct some heavy duty socks that extend up to the knees. This will give it more strength to support his huge melon.
*Next construct a giant diaper around the hips. This will prevent him from tilting forward.
*Continue your way up the body to the neck. Construct a nice neck brace that butts up against the base of the head. This is to strengthen it as well as beef it up a little so its not a pencil neck. (keep in mind you don't want to add a lot of extra weight here since it will already be top heavy)
*Finally plug up all the holes on his head (except the coin slot on top)
*Be sure your bank is in a well balanced position for drying. Its a good idea to prop it against something stable to avoid tilting while drying. Let  it sit and dry as directed on your clay. (Mine took about 2 days)
NOTE: Remember as you work with the clay that it doesn't have to look perfect. A lot of it will be covered later, and those that are exposed will be sanded smooth.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
