loading
Step 5: Bench Sprocket Assemble
To bench assemble a plasma-sprockets with 4 side sections and 2 gear sections use the following steps...
1. Do a little experimentation to see how much of  a gap is needed between the gear sections and the side sections, noting that there are two sides. Then find combination of washers and/or over-sized nuts that create this spacing on each side.
2. Take two of the sides and place a bolts though them facing upright.
3. Place the one layer of spacers on top of the bolts.
4. Place the two gear sections on top of the side sections noting that the two seams are supposed to be at 90degrees to each other.
5. Place the other set of spacers on top of the gear sections.
6. Place the other two side sections on top of the spacers (A little persuasion from a rubber mallet might be required to line everything up at this time).
7. Put nuts on top of the side sections and then tighten them all gradually with some kind of thread locking.
8. Check that everything lines up correctly.
I think that your design is awesome... and reduce the installation problem....
That Torchmate looks like tons-o-fun!
The plasma hardens the teeth for you?<br> <br> L
I have noticed that the heat of the plasma cutter does hardened the teeth, but I have not yet had a chance to use a rockwell tester to determine just how much. At any rate it should be enough to extend the life of the sprocket.
About This Instructable
11,292views
41favorites
License:
More by Mechtechnal:Off-Grid Comm Hub with Geiger Counter, Flashlights, & P-AC Solar Personal AC & Phone Booster Apocalypse Mechanics Machete
Add instructable to:
