Easy Toboggan From a Plastic Barrel
47,189
359
47
Posted in OutsideSnow
Introduction: Easy Toboggan From a Plastic Barrel
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
Perhaps you're like me, and have always dreamed of making a traditional bent-wood toboggan. However, like me, you realize that doing so requires a lot of time and tools you may not have. So I was thinking . . .
How can I easily make a toboggan that's both fast to make, and FAST on the slopes?
Ideas began to formulate in my wee brain for a non-traditional toboggan, and after some time in the shop here is the finished result!
This is a wicked-fast toboggan, made simply from the following items:
  • 55-gallon plastic barrel
  • two-by-fours
  • handful of screws
  • rope
  • wax!
This is pretty straight-forward, and only requires a few basic tools. Make sure you've got some affordable health care and . . .
Let's go tobogganing!
Step 1: Materials
I picked up a used plastic barrel through my local classifieds for $10. It originally held some kind of detergent. Large car wash facilities are a great source for clean-ish barrels like this, for use in diy projects.
I originally planned on using maple wood for the side boards (as shown), but this lumber got appropriated for a different project. So I went with 2x4s instead, which worked out better anyway.
Step 2: Measure and Mark Barrel
The runner for the toboggan is made from the side section of the plastic barrel, which will be cut out with a jigsaw.
I rigged up a simple marking device with some wood scrap and a marker.
The runner I made is 22 inches across, so I marked the barrel accordingly from both the top and bottom so the raised ridges on the barrel sides were lined up symmetrically on the piece I was going to cut out. See photo notes for additional details on marking the barrel.
Step 3: Cut Out Runner From Barrel
To cut up the barrel, I only recommend using a jigsaw. It is the safest, easiest, and quickest way to do this.
First, drill a 1/4" (or so) hole at the top and bottom of the vertical line. Then carefully trim off the top and bottom of the barrel.
Then cut through the vertical line.
Step 4: Flatten the Runner
I put a lot of thought into how to best to use this middle section of the barrel as a toboggan runner.
What I ultimately concluded was that the perfectly smooth inside of the barrel is the part we want in contact the ground. There are bumpy letters and other markings on the outside that we don't want dragging in the snow.
Also, by doing it this way, we take advantage of the slight top-to-bottom vertical curve of the barrel. Putting the inside down creates edges of the runner that curve down ever-so-slightly, and act as sharp guiding edges (kind of like on skis and snowboards).
. . . So we need to flatten this curly middle section of the barrel as much as possible.
The easiest way to do this is to roll it tightly in reverse by hand a bit at a time, to break the "memory" and flex the material until it rests in a mostly flat position. This requires a bit of muscle and elbow grease, but it's not too hard to do.
It may also be helpful after the runner has has been worked manually, to just roll it up tightly in reverse and duct tape it together while you work on the other parts. That's what I did.
Step 5: Wood Pieces
There are two wooden braces that run the length of the toboggan, made from 60-inch pieces of 2x4. Any timber will work, as long as it is wide enough to bore holes out on the bottom side to hold the knotted ends of whatever rope you use (see later steps for details on this).
There is also a front "handle" piece of wood that goes onto the front of the toboggan (shown in photo 2), and an additional piece of 2x4 that will be installed as a brace between the front tips of the side boards (shown later on).
Step 6: Prepare Tips of Side Boards
The side boards have a slight curve cut into the front end.
See note in photo one for dimensions where to mark and cut. These cuts can be done easily with either a band saw or a jigsaw.
Step 7: Layout Marks for Rope Handle Holes
I put three handles on each side made with rope that were threaded in place through bored out holes in the side boards, and held in place with captive knots. Each handle is made from an individual section of rope.
If you would like to duplicate my layout for handles, see notes in photo two for measurements and tips on spacing.
Step 8: Bore Holes for Rope
From the bottom sides of the boards, I bored out holes that were 7/8" wide and about 1" deep to hold the knots. (I used 3/8" rope.)
The center line of these holes were transferred to the sides and then to the top with a framing square. Then the holes were bored from the top side with a 1/2" bit down to meet up with the larger bore.
Not shown here, but important:Bore holes in the same fashion through the front of each side board at the six-inch mark. Rope will be attached through these holes to hold the front part of the toboggan in place, and also act as the tow-rope.
Step 9: Finish All Wood Pieces
If you want this to last a long time, I recommend finishing all the wood pieces with several coats of spar urethane, according to the directions on the can.
Be sure to sand between each coat lightly with 220 grit sandpaper so you end up with a very smooth finish.
Step 10: Optional: Add Racing Stripes!
After adding my final coat of spar urethane, I decided to add some blue racing stripes.
I used tape to mask off where I wanted the stripes to be, and then sprayed on a coat of clear lacquer first. This seals the edges of the tape, so any "bleed-under" from this first coat is actually clear. This ensures that additional coats leave a crisp and clean-looking paint line.
I then sprayed on a few coats of blue spray paint, and removed the tape. Racing stripes!
Step 11: Cut Rope Sections for Handles and Tow Rope
Each section of rope used for a handle was 24 inches long. The quickest way to "fuse" the ends of the rope in this case is to simply wrap the area you are going to cut with masking tape. Then cut through the middle of the tape with a utility knife, and both ends are done. Easy peasy!
For the tow rope I cut two 5-foot sections of rope with the ends finished in the same manner.
For all sections of rope, I tied a knot in one end to prepare them for installation into the boards. See photo 2 for some tips on this.
Step 12: Install Rope Handles and Tow Ropes
The rope handles and tow ropes are installed now.
Thread each handle up from the bottom and down the proper hole. Tie a tight knot and glue if desired, and pull the handle back up tightly to seat the knot in the bottom hole.
Do likewise for the front tow ropes.
Step 13: Attach Front Edge Board
The little board that goes at the front of the sled serves a couple purposes. It acts as a handle when riding, but also as a stiffener and support for the tow rope.
I clamped this in place at one end of the runner, onto the smooth down-side. I attached this to the runner with several 5/8" screws into predrilled and countersunk holes.
Step 14: Attach Side Boards to Runner
The side boards are attached to the plastic runner with screws installed from the bottom side.
It will help if you have a couple of nice sawhorses to place your almost-finished toboggan on while you work on it.
I used some 2" screws that were salvaged from some old thing I took apart years ago. I'm not even sure what it was, but these screws had a nice big head on them.
If you're making this and looking for screws to buy, I recommend looking for something similar to the one shown in photo 3.
The trick with this step is to clamp the runner in place to the boards, and predrill and countersink your holes.
I worked from back to front, one board at a time, and clamped right next to where I was putting a screw and moved the clamp forward as I worked. Make sure you avoid putting any screws in too close (or right on top of) the holes that are holding the ropes!
Step 15: Add Front Brace
A front brace made from a piece of 2x4 was added between the front tips of the side boards. This was screwed in place through the side boards and also from the front side through the plastic runner.
This was actually a late addition, but was greatly needed. It keeps the side boards from splaying out, and really solidifies this curved (and most-stressed) section of the toboggan.
Step 16: Install Tow Ropes Through Front Board
Carefully drill a 1/2" hole through each side of the board at the front of the toboggan.
The two ropes that make the tow rope are installed through these holes, and the front end of the toboggan is pulled up and curved to your liking and held in place by knots tied in these two ropes. The two loose ends are then tied together.
You're almost done!
Step 17: Add Padding/boot-grip Surface
Update! This feature was actually added after our first outing with the toboggan, but I'm inserting it here rather than in the "Improvements" step.
After our initial tests with the toboggan, I realized I could easily add a bit of padding that would double as a boot-grip surface. This was made from some anti-fatigue floor mats that were cut to shape and glued down with contact cement.
There aren't many adhesives that work with polyethylene, however I've had decent luck with good old fashioned contact cement (NOT the junky CA-approved white, watered-down garbage--it must be the original yellow stuff).
See photo notes for details on installing the pads.
This has been a great addition and and I highly recommend including some kind of simple padding like this.
Step 18: Wax It
I wasn't originally planning on waxing the plastic runner, but I'm sure glad I did. This turned out to work far better than I had hoped!
I used a block of basic paraffin wax and rubbed it all over the bottom of the runner, and onto the screw heads. I then used a propane torch to quickly go over the wax just long enough to melt it onto the plastic, and into the screw heads.
This was kind of a test, and I was sure the wax would just flake off of the plastic as the runner flexed and moved while we were sledding.
However, after a day of sledding, the wax on the flat surfaces was still stuck on. It was pretty much impregnated onto the surface, just like a pair of skis!
So, before you head out tobogganing, be sure to wax your sled!
Step 19: Go Find Some Snow
If you live in a place where you've been getting less-than-normal amounts of snow, you may need to drive to find some.
Fortunately, I only live about 30 minutes from some of the greatest snow on earth. We headed up into the mountains and found a decent place to use our new toboggan. It was a blast and the kids are dying for it to snow so we can use it closer to home!
Pop Quiz:
10 points if you name the mountain in the photos.
100 points if you've been to the summit.
1000 points if you've been to the summit in the snow!
Step 20: Improvements
There are only a few things I'd change if I were to make this again. These may be options to consider for anyone that wants to build a toboggan like this.
See photo one. I've kind of fixed it, but the very tail end of the runner had a pretty substantial downward curl to it, which surely slowed down the toboggan on our first outing with it. To fix it, I heated the plastic up with a blow torch until it was soft and flexible, and then clamped a board to it until it cooled down. This flattened it out for the most part. However, if I were to make this again, I'd simply trim the back bottom edges of the side boards as indicated, so the tail end of the runner flares up just a bit.
See photo two. There are a couple of issues here. The wax that I melted into these areas to cover the screw heads just popped out, which I wasn't surprised about (I was more surprised that the wax stayed put onto the plastic). I debated using stainless steel screws for this, so if you're concerned about the screws rusting through, you could consider that as an option. But they would be pricey. My conclusion was that even using basic screws, they would still probably outlast the wooden sideboards, even with the several coats of spar urethane I applied. If a person really wanted to do this "right" they'd use stainless steel screws throughout, and retreat the wood portions on a yearly basis. However, I don't think that's worth the time or monetary cost!
See photo three. Initially, I was worried about the waviness of the runner, but after using it I think those waves make no noticeable difference in performance once a bunch of people are sitting on the sled.
One more thought: I was tempted to put additional cross braces between the side boards, or even build in some kind of wooden seats. In the end I decided not to, opting instead to try to keep this as light and minimal as possible. I guess this isn't really an improvement idea, but more of a "in case you're thinking likewise, here's my two cents on the matter" parting thought.
And there you have it.
I figure if we get a few years out of this, the level of effort and money I put into it was worth it (about 60 dollars and a couple of afternoons).
The plastic will probably last indefinitely, so I could just replace the wood, screws, and ropes if needed!
Step 21: Have Some Fun!
I hope you make your own toboggan!
If you do, be sure to let me know about it in the comments. I'd love to see a photo of it and hear how it went!
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    47 Comments
    This is awesome. I bet this would do well on sand dunes too!
    LOTSA WAX like surfing Heck you could start a craze!!
    Then add a 6 foot box kite......and a keel board(you would need to have it to go straight).
    Also would need paid up health insurance, disability insurance and a driver who can take you to ER. But what a hoot!
    Check out land/sand Yachting.
    This instructable is so apt for modding!
    Ooh, good thought! I like pretty close to some dunes, so we may have to try it out!
    ELEGANT,
    SWEET,
    SIMPLE!
    I humbly suggest putting a foan strip along the top edge of the front of it, sa as kids go flying it stops really bad landings. (a tad) And foam in the tail s of the rails as that is good for kids who slam into you. As someone who who has been in sufficient sledding catastrophe's I assure you it is a good idea!
    great instructable,
    Excellent ideas! Thank you!
    Great design! I'm pretty sure it also works on grass slopes on a rainy day. Why worry about the rain?! Let's use it!
    rub on some dishsoap if you want to do grass sliding! You can paint it on and let it dry or hit it with some ground up left over soap bar reminants and it will go faster.
    Thanks! I think it will also work on stairways . . . but we're waiting until the kids' mother is away before we try that! ;)
    We don't get snow often, but this would be great to have on hand the one or two days a year that there's snow on the ground!
    I wonder if it would be feasible to cut two thin strips from the unused sections of barrel, and then adhere them to the runners as a 'cover' for the screws? (Not sure what adhesive would be best...maybe hot glue.)
    An alternative might be to simply fill the screw heads with hot glue, and then sand smooth.
    Since we are lucky to get a couple of inches of snow, the foam padding would be necessary for comfort.
    This is genius! We used everything as a sled growing up but never one of these :D
    Will be sure and have one ready for next winter. Grand kids will love it! Good, clear instructions and images.
    Thank you, I'm glad you found this! Your grandkids will most definitely love it.
    That is brilliant and awesome!!
    Thank you! I was very happy with how it turned out, and it's been loads of fun.
    i love this! well done! one of my favourite things about Instructables is watching how people repurpose things in unexpected ways and you've done a great job at that (i want to try it now!) thanks!
    Well made, simple build. This on my to do list. ??
    I just finished building this sled as a Christmas gift for my girls. I can't wait to see their reaction when they see it Christmas morning! Now we just have to wait for some snow/ice to hit north Texas. Thanks for the great idea and Instructable!
    Excellent! My kids actually used ours today on some fresh Utah snow on a much steeper hill than we tested it on last season . . . and it was dangerously fast!
