3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plastic Bottle "Stained Glass" Candleholder
Step 2Destruction of plastic
destruction of plastic
The first bottle you cut saving the base of the bottle to become the base of the candleholder. The pieces are layered on top of each other with the opposite side from cutting out becoming the second layer.
The second bottle is cut just from the center part with no base or top. Each layer will get sandwiched on top of each other to become contrasting layers of stained glass
I just cut them all freehand but if you wanted to you could easily trace a pattern on with a whiteboard marker and use that to cut then wipe it off before coloring in the design.
3 comments
Apr 19, 2010. 8:42 AMkukopia says:
What did you cut them with?
Sep 19, 2011. 6:39 AMSkipper jr says:
With scissors, what else would you cut them with.....your finger
Jan 10, 2009. 11:04 AMjeff-o says:
You could also stick down masking tape and draw your pattern on that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:CrystalStranger
