loading
Picture of Plastic Milk
I was trying to find a recipe I could use to produce a chemical reaction for the Mad Scientist contest and the chemical reaction contest. I came across this one and thought is was interesting. For this tutorial I will be making Plastic milk.
Step 1: Recipe
Picture of Recipe
Recipe ingredients:
  • 2 Cups Milk
  • 2 Tablespoons white vinegar
This recipe came from here: http://www.youtube.com/watch?v=pIvAl4lu1uA.
It is very helpful to view this video so you can see the process of making plastic milk.
It is a quick and easy project.
Step 2: Utensils
Picture of Utensils
Utensils needed:
  • Liquid measuring cup
  • Measuring spoons
  • Coffee filters to absorb the liquid
  • Fine weave strainer
  • Spoon
  • Plate
  • Pan
  • Cookie cutters
  • Skewer not shown
  • Wax paper not shown, line the plate with wax paper.
Step 3: Measure/ Heat
Measure:
  • Measure 2 cups milk and set aside.
  • Measure 2 Tablespoons white vinegar and put it into a small glass reserving until later.
  • Line the strainer with 2-3 coffee filters or paper towels.
  • Line the plate with wax paper.
Pour the milk into the pan and heat on stove. Do not boil! Heat until almost too hot to touch but not boiling
  • Add vinegar.
  • Stir gently.
  • Allow it to separate into globs.
  • Stir again.
Step 4: Strain
Picture of Strain
Remove from the stove:
  • Place strainer in sink.
  • Pour Contents into the lined strainer.
  • Allow to drain a couple of minutes.
  • Carefully pull up the filter and gently press with your fingers to remove liquid from ball.
  • You might need to place it in another doubled coffee liner and squeeze again to remove excess moisture.
  • It should begin to form a paste.
  • Let it set 5 minutes.
Step 5: Molding
Picture of Molding
Method:
  • Gently roll the plastic in a tight ball.
  • Gently press flat to form shapes.
  • This part is tricky you need to work with it and try to keep it together nicely.
  • You accomplish this by pressing down and pulling toward the center with your hand.
  • Using the cookie cutters make the shapes.
  • Form a couple of balls if you desire.
  • Using the skewer poke holes where you want if you are going to make jewelry.
Step 6: Place Shapes On Plate
Picture of Place Shapes On Plate
Place the shapes on the plate lined with wax paper:
  • Place the shapes on a plate.
  • Set in a safe warm area away from children and pets.
  • Allow to dry
  • Turn over after a few hours to allow the back side to dry.
Please note: I made a ball because they mentioned it was rubbery and I thought I would see if it bounced. We will see.
Step 7: Uses
Picture of Uses
Uses:
  • Allow to completely dry before working more with it.
  • You can make shapes from the plastic clay.
  • Paint it when it is dry.
  • Write on it.
  • Make jewelry.
  • If you can mold a perfect circle it bounces.
  • Embellishments for many things.
  • Gift tags.
  • Dog Tags.
  • Key ring tag.
  • Picture frames?
  • Dolls.
  • Game pieces.
This list is very long.
I can't wait until the paint dries so I can create something that I will post here when it is done.
Step 8: Sunshiine's Final Thoughts
This was a fun experiment. It would make a great craft project for the family.
What I did was turn milk into a solid through a chemical reaction known as a polymer molecule strand.
The individual protein strands within the milk and the vinegar solidified making plastic.
The plastic is based on a protein called casein - adding the acid causes it to unfold from its usual tangled form,and change into longer sections, which are the lumps that are removed to form the ball .
Casein-plastic used to be used to make shirt buttons.
Some cheeses (like the processed cheese slices) are made in a very similar way, so can be genuinely called "plastic cheeses".
I Painted the shapes thinking I would glue them on boxes for embellishments or make jewelry. I am very happy with the results.
Thanks you for stopping by and please check back soon as I am working on some interesting things to share.
Have a nice day!
Sunshiine
1-40 of 85Next »
Ftnsbi3 months ago
why is it not edible ??
sunshiine (author)  Ftnsbi3 months ago
It is very very hard like plastic. It probably would not taste good at all. I hope this helps. Have a great day!
sunshiine~
dragon fllyer6 months ago
What this really is is cheese...
This recipe is false, but with a spoon of caustic soda, this recipe became a real plastic, the galatite.
gravityisweak11 months ago
Ok so I'm curious. If you start with milk, and add vinegar then remove the casein, what do you have left? Is it still milk? Or milky vinegar? Or something new altogether?
sunshiine (author)  gravityisweak11 months ago
Hmmm, the best I can describe it would be a jell-0 type of substance that is not completely set up. It is still very soft and mushy but as it dries it firms up. At this point one could not make a shape from it because it will not hold. Hope this helps. Thanks so much for stopping by and do have a splendorous day.
sunshiine
EmiClarice1 year ago
Then, I looked at this instructible and saw what I did wrong. Thank you!!
sunshiine (author)  EmiClarice1 year ago
Awesome!
OMG I remember doing this in a science after school program! Mine turned out like feta cheese.. :)
Yes, it is a lot like feta cheese but if I recall I kneaded it a little to form a ball. Thanks for stopping by and commenting and do have a great weekend.
sunshiine
Is it edible? Just asking...
sunshiine (author)  akshat210451 year ago
No it is not edible. Thanks for stopping by and have a great day.
sunshiine
Oh. Thanks in advance.
You welcome.
This molds and gets pretty gross after a while. :P
and when it grows mold it STINKS!!!
sunshiine (author)  electricitis1 year ago
Thanks for commenting but I have had mine for over a year and it has not molded. Weather may be a factor as I live in a dry climate.
Cheeeeeeeesssseee
thanks alot ghys i really liked it this is for my scince project
THANKS SUNSHINNE
them8triark2 years ago
with this, are you able to finely sand the pieces if you want to?
sunshiine (author)  them8triark2 years ago
I have not tried that but I would think you could. What is difficult is molding the pieces because it does not stick together like clay. I only made these one time. Maybe adding something that would stick to the milk better so you could mold it more smoothly? It doesn't hurt to try different methods. I hope this helps! I enjoyed making these! Thanks for asking and do have a splendorous day!
sunshiine
FrozenIce2 years ago
Woohoo for the cross!
sunshiine (author)  FrozenIce2 years ago
Thanks for stopping by and commenting! Have a splendorous day!
sunshiine
Thanks! By the way, your name reminded me of a song:
Thousand Foot Krutch- Sunshyne
http://www.youtube.com/watch?v=_3n-gZ37JkE
Checked out the song! Thanks so much for sharing!
sunshiine
Can yuo tuoch the plastic to molde it?
sunshiine (author)  Moco cochino2 years ago
Maybe if you allow it to dry a while because this is not as firm as clay. I hope this helps and thanks for commenting!
Sunshiine
Okay
ChrysN2 years ago
Hi, Sunshine, Congrats on being a runner up winner! I was wondering if you can use expired milk? I have some in the fridge right now that ruined my morning coffee, but I thought that since there is quite a bit left to make some plastic from it.
sunshiine (author)  ChrysN2 years ago
I forgot, I think the best way to do this is just follow the instructions. I was thinking your milk was clumpy already but no, just follow these instructions and it should be fine. Sunshiine
Thanks, I will give it a try and let you know how it turns out!
Thanks!
It worked fine. Once I started heating the milk it already began to separate. I still added the vinegar though. I was worried that it might be stinky but it didn't smell very much and once it dried, it didn't smell at all.
Hi CHRYsN! I am pretty sure that will work. Just follow the directions except omit the vinegar. Please let me know how it turned out if you make it and I will add that information to my instructable. I just don't see why it wouldn't work. Have a great day and thanks for stopping by! Sunshiine
babelsgp3 years ago
Congrats! I noticed that you also wanted to paint what you create, I wonder if the paint made from milk would adhere to itself? http://en.wikipedia.org/wiki/Casein_paint
sunshiine (author)  babelsgp3 years ago
Might be worth a try! Thanks for sharing!
Possibly before the plastic dried?
In reading through many of the comments, I didn't see anything regarding the smell. I am thinking about doing this for a scientific art project for kids, but want to avoid a room full of drying expiring milk stench. How stinky is it when it dries?
sunshiine (author)  kristinsilver3 years ago
I apologize for not answering this question sooner but my PC died. I would think it might be offensive if you had 30 of them but thought of a possible solution. Perhaps drying them in sand covered in a box with air holes at the top might work. A simple experiment might be worth it. Thanks for commenting and have a nice day!
Sunshiine
techturtle23 years ago
Can you speed up the drying process by heating/cooling the plastic?
1-40 of 85Next »
