3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plastic Molds- An Intro
OK- Let me try this again. I was posting with specific reference to the full belley project (Peanut Sheller) but apparently there is substantial interest in plastic molds.
Injection molding comes in several different varieties,but can basically be described as forcing liquid plastic into a metal mold under high pressure. Most injection molding is done with high temperature molten plastic, and then it quickly cools inside the mold. The part is taken out of the mold, and then the process is repeated. The benefit of this technology is that thousands or millions of components can be made very quickly, and inexpensively. The downside of this technology is that the mold is usually costly. (lots of variables here- design life of mold, cycle time, etc) Usually you would use this technology to make thousands, or tens of thousands of parts- this makes the cost of the mold very small on a per part basis.
There is another technology called RIM (reaction injection molding). These molds are less costly than the other, and in this process, cool liquid plastic is injected into the mold, where it sets up chemically. (like epoxy or fiberglass, only a polymer plastic)
To begin along either one of these paths, you need to start with a product that is designed with molding in mind as the production process. There are many product details that may make a part easy or difficult to mold.
If you have a basic product concept or design, then you need someone to develop it into a full 3D CAD model. I have attached an example CAD model for you to see.
Beyond this point, the costs and direction you should take will vary widely, depending on the size and nature of your product.
Dwayne Esterline
GI Engineering Co.
>>>>>Hi-
I was browsing previous comments, and thought I would give my 2 cents.
If there is really interest or demand for significant quantities of molds, I can help with developing an injection mold and producing plastic versions of the fiberglass molds.
There are various high strength polymers available, but I bet we could produce mold sets for under $10 per set. We would have the capability of producing them in the hundreds or thousands or tens of thousands. High quantities would be even less expensive.
For comparison, think of the 5 gallon plastic buckets and plastic lawn chairs available. The manufacturing process is the same, and the equipment is readily available where I live.
Any thoghts?
Step 1Develop a 3D CAD Model
The first step for injection molding is to develop a 3D CAD model of your product. (Computer model)
In this process, a designer takes your concepts, sketches or prototype, evaluates it for moldability, and then draws it inside of a computer environment.
Why? In modern mold manufacturing, all of the machine equipment is driven by computers. Your design can be evaluated by computer and the mold will be cut by computer operated machining centers.
Through this process, an experienced designer will advise you on the changes that may be needed in order to make the molding process as inexpensive as possible.
A good CAD designer can work from your sketches or drawing, or even a rough prototype.
Many companies can provide this service. (Do an internet search for product designers)
I have been designing tools, equipment, and manufacturing processes for many years. I use SolidWorks and AutoCAD design software.
You may learn more about my company on our website www.giengineeringco.com
Dwayne Esterline
20 comments
Nov 29, 2011. 10:09 PMtayv says:
I just started using solidworks, and bought the SolidWorks 2011 book which covers beginner to advanced topics, and is very comprehensive. I often use the book as a reference to go through.
You can get it @ http://solidworksbook.com/
Sep 6, 2006. 1:32 PMewilhelm says:
Hi DEsterline, Typically, this is the type of thing that would get removed because it has no instruction. However, it looks like there's a fair amount of interest in plastics molds. How about you use this as a place holder for publishing an Instructable on making plastic molds (maybe unpublish this one, edit it, and republish?) We're working on tools that will make this sort of conversation easier without having to post it in an Instructable.
Jun 22, 2010. 8:33 PMfdavies says:
Hi Boss, I started making my own injection molds about 25 years ago. They are made specifically to run on my injection molding machine. The process of making a mold is deceptively simple. Machining is just one aspect of this process resulting in a usable part. It is a fusion of design relating to function and cost effectiveness. Designing the mold is related to designing the part, as all parts must be designed to be manufacture-able. I may be interested in writing a series of articles relating to the topic with the novice in mind. I learned how to make a mold from a fellow mold-maker, ...referred by the manufacturer of the molding machine, followed with a thorough reading of a book entitled: 107 Injection Molds. The book looked at 107 different problems and mold design solutions. All molds are not alike, and while some are hand placed and pried open, others are just slightly less complex than a submarine. The temperatures and pressures involved are dangerous and a mold could potentially explode if not correctly designed. The question here really becomes... what part to design and instructable about? Any thoughts? Keep it small, about the size of a lighter and I might be interested in molding a few parts should anyone actually complete a mold. -Frank
Sep 30, 2010. 9:39 AMcatgrahn says:
Frank, I would love to know where you are located as I have some ideas that I could use some help with.
Cat
garycat@rogers.com
Sep 30, 2010. 12:41 PMfdavies says:
Hi Cat,
I'm just south of Tumwater Washington USA.
Looking forward to your project.
Frank
Mar 20, 2009. 3:35 PMchaiken says:
As you can see if you look up my "bite-valve hydration system" posting, I have a long-term interest in learning injection molding. I'm sure I can make molds myself, as I have access to a machine shop, but I guess that my design will have to go through several iterations, as I have only made my part on the lathe so far. I have access to 3D CAD, but could use a pointer to a "how to design simple injection-molded parts." Also, I'd like to either find an injection molding company here in the SF Bay Area of California, or find a vendor who will allow me to try several small runs of a design once given a deposit on a larger order. Do you have any advice in this regard? TIA.
Apr 4, 2008. 3:09 AMCharlie1138 says:
In the example for the plastic molding process that didn't require high pressure molds, the only items listed are soft plastic products. Is it possible to make products with a more rigid harder plastic as well? Like the material keyboards are made or mouses, monitors, laptops etc?
Nov 28, 2007. 3:09 PMbowlman says:
How about a simple 3-4 part assembly instructable?
Aug 17, 2007. 5:08 PMchrissis1111 says:
I am very interested in making molds, please contact me if you are still interested in helping.
Sep 6, 2006. 11:32 AMwinwintoo says:
I'm interested. I have a project that I didn't know how to get moving. More information welcome.
Sep 6, 2006. 8:03 AMradiorental says:
if you could help the full belly project out that would be awesome
http://www.instructables.com/id/ERSV3ZTAA8EP287HYR/
p.eace
Sep 6, 2006. 8:43 PMCrash2108 says:
There really needs to be forums here..
Sep 6, 2006. 4:19 PMtrebuchet03 says:
YES YES and YES! I have been searching for a cheaper alternative to the two part silicone mold material... If you can provide just information, that would be phenomenal :D hehe, I even tried using a batch of urethane clear coat... I tried adding very little hardener and then letting it gell... bad results (but a cool video :P).
Sep 6, 2006. 3:20 PMuchujin says:
Definately would like to know more. I usually use polymorph, but it melts at 62 degrees, so not entirely reliable
Sep 6, 2006. 10:46 AMLiganic says:
Any Pictures how they would look like? Or some sort of portfolio?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:DEsterline
