3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plastic Soda Bottle Prosthesis
Please cast your vote for the CIR's Pepsi Refresh submission to Provide Cost-Effective Prosthetic Care in Underserved Midwestern Areas - http://pep.si/eo57my
We would like to thank everyone for their kind comments, ratings, and votes. A video demonstration of this process has been produced and uploaded to YouTube. In addition, the Technical Note previously submitted to the Prosthetics and Orthotics International Journal has been accepted for publication in the near future. If you would like to know more please feel free to contact us.
In resource-limited areas worldwide, individuals with amputations may not be able to gain access to prosthetics devices due to a lack of the materials needed to fabricate them. This simple technique utilizes a 2-liter soda bottle to create below-the-elbow prosthesis suitable for a number of light-duty activities.
Please note well that this technique is intended for use by trained prosthetists and it is intended to be preformed only using a plaster cast of the residual limb.
The contents of this presentation/publication were developed under a grant from the Department of Education, National Institute on Disability and Rehabilitation Research grant number H133E030017. However, those contents do not necessarily represent the policy of the Department of Education, and you should not assume endorsement by the Federal Government.
Materials:
- 2-liter plastic soda bottle
- heat gun
- formed plaster model of residual limb (amputation stump)
- hose clamp
- section of 1/2" PVC pipe
- band or manual saw
- utility knife
Step 1
1. Remove the bottom of the bottle and place over the plaster model. Then apply heat to the lower portion to form the trimline.
113 comments
1-40 of 113next »
Sep 7, 2010. 1:45 PMescapefromyonkers says:
i really like this instructable, i just stumbled across it, i wonder i i could use a mod of this to make a mold of my left leg , below the knee, mainly calf muscles, which is very muscular and make a snap on PET for my right leg below the knee, which is extremely atrophied due to spinal injury, the muscle are denerved, fibroids now.
if i could make a snap on PET form, it would not be weight bearing at all ,
purely cosmetic , Matching skin tone may be to far out of my reach' much, but if i made it to sock height it still would be huge improvement,
i may try the technique used in making an AFO , plaster positive that is split , and see if i can make a snap on PET.
it be interesting. IT is purely cosmetic, no weight bearing., probably cover it with a sock.
Apr 29, 2010. 11:49 PMEggHead101 says:
Oh I forgot to mention. . . . Adding labels to the various "attachments". This way if a friend is over ... or someone. You could say "Hey can you bring me my "multi-tool" attachment?" Or my bottle opener ... you get the idea !
I saw somewhere a modified "Grabber" that attatched and was used by extending the elbo to grasp, and release when pulled back, but I can't find it anymore. It was a hand made device. It was also reversible.
Apr 29, 2010. 11:39 PMEggHead101 says:
Fantastic.  I would make Two though. One as described and another that utilizes the threads on the bottle.
Easy enough to glue or screw a cap to something usefull = fast swap.
Also using the Pipe/hose clamp is wonderful - I would swap out the standard "screw" for a large Wing-nut so one can easily swap devices without needing a tool to loosen the nut / screw...
Wonderful Instructable
Mar 12, 2010. 1:22 AMRanie-K says:
I have a cool, but less "idealistic" application for this great idea:
PLASTIC BOTTLE CAMERA ARMOR:
Make a positive copy of your camera: Cover it with a condom (or robber glove sleeve) and plastic wrap. Roll on a layer of soaked plaster bandage. Let harden and take apart. Coat with petroleum jelly or dish washing liquid. Re-assemble and fill with plaster. Let harden for several days, remove mold and polish positive.
Measure that the positive is as big as the camera. If not, tape a material like 1mm thick cardboard to the flattest sides -perhaps also over the display area, so the armor will be 1mm away from the screen.
Then do the same process as for the prosthetics, and cut holes where you need to access buttons and tripod threads.
Instead of pulling out the positive, you may need to destroy it to get it out; don't bang the plastic too much in the process, since that may discolor it.
Mar 11, 2010. 4:06 PMwiley coyote says:
Very Cool use.  Brilliant!
I've used this material in similar ways, for other projects and it is very durable and readily replaceable, if you screw up.  You cannot get better than that.
Very useful for sealing, or coupling, the ends of tubes as well.
www.instructables.com/id/Pop_Bottle_Heat_Shrink_StrapsTubing/
Jan 21, 2010. 2:25 PMThur says:
It's amazing what one could do with a little ingenuity. Just imagine all of the wasted bottles cluttering the landfills. Funny how we don't realize the potential of such common things.
Oct 30, 2009. 9:42 PMbeehard44 says:
 maybe kipkay will be motivated and make a burning laser prosthesis.....
Jul 17, 2009. 7:45 AMIyer2711 says:
You have no clue who all would thank you for this. Wow!
May 2, 2009. 9:27 PMyokozuna says:
Fantastic, a deserving winner, five stars. Any ideas for easy hand tools that could interchange into the PVC (maybe more versatile than the paintbrush)?
May 4, 2009. 3:34 PMyokozuna says:
Nice video, you should imbed it in your instructable.
Feb 5, 2009. 8:46 AMepfroth says:
This is a truly brilliant idea, with enormous potential. It seems that the heat gun (and electricity to run it) could be the weak link in some resource-poor settings. Does boiling water provide enough heat to deform the plastic? What about a pot of sand heated over a fire?
Feb 27, 2009. 10:27 AMMadrigorne says:
Tail pipe of a motor vehicle will work, so long as it is running.
Mar 11, 2009. 8:23 AMflatcurve says:
Hot oil might work as well, since it can be heated much hotter than water, up to 400 degrees.
Feb 28, 2009. 10:48 AMsquarefodder says:
i am a certified orthotist and prostetist my specialty is the lower extremities. I own a company that fabricates these devices and fits on patients. to give back to the world i go to hati to help doctors without borders also i help my local community when possible. getting an infrared oven oven into a 3rd world country with no electricity can be tough to say the least. this is a neat way to fab a quick device for the upper extremities. I am very impressed and will utilize this idea the next time i go. thanks so very much for the idea.
Feb 22, 2009. 2:32 PMthepelton says:
Could heat shrinking soda bottle plastic over plaster be used to make a mask, after making a plaster cast of a face?
Feb 5, 2009. 6:39 AMshwa says:
Coming from third world country and war inflicted area,where many victims of war were amputees,most of whom couldn't afford decent prosthesis ,i think this is the one of the best instructables ever,hats off to you...
Feb 15, 2009. 3:36 PMthepelton says:
I agree. There are a number of places such as Afghanistan and Khampuchea where people have picked up odd looking things only to find they were mines at the expense of a hand. This could do a lot to give such people a sense of self worth.
Jan 30, 2009. 11:54 PMsmilestill says:
Interesting Concept. I would not think it would be structurally sound enough for use. It may very well function as a check socket, though I would have to see it in person to verify that.
Feb 15, 2009. 11:26 PMthepelton says:
In the photo, you had what appeared to be a paintbrush attached to the end. I suppose an amputee could paint with this. The only problem I could see would be cleaning the brush.
Feb 5, 2009. 4:45 PMLagather says:
Another possibility might be to replace the plastic bottle for the stump socket with corn starch based plastic.
http://www.instructables.com/id/Make-Potato-Plastic!/
Feb 6, 2009. 3:27 PMLagather says:
Actually, the Brendan who demonstrated the potato plastic is a different Brendan. From the comments on his post, people are trying to figure how to apply his plastic. I don't know how accessible glycerin is in developing countries, but it might lead to a stronger and more durable prosthesis. I think that the process might be able to use some of the same steps as your original process. The starch plastic has to cool and dry. The plaster of paris positive could help the drying process. Anyway...it might be a good follow up to your original publication/research.
Feb 15, 2009. 11:14 PMthepelton says:
Glycerin is derived from animal fat. It should be quite available, as long as there are no objections about it's coming from animals. I suggest you read about the origins of the Sepoy Mutiny, in regards to objections about glycerin's sources.
Feb 12, 2009. 10:13 AMyotnomuk says:
Congrats on the win
I was wondering how (un)comfortable it would be to have this plastic essentially wrapped around the skin for an extended period of time.
Would doing what this person does helps letting the skin "breathes" ?
http://www.instructables.com/id/SI7BKOOFPQL8O7H/
Feb 7, 2009. 6:06 AMsiderits says:
Outstanding, can this plastic be melted and recast or extruded for attachment points?
Feb 7, 2009. 3:59 PMsiderits says:
Just in passing, my instructable is the battery operated centrifuge for use in cytology processing in countries with limited economy. Wonder if instructables might want to break out "do the world some good" projects similar to these. Best regards
1-40 of 113next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:CIRnetwork
The Center for International Rehabilitation (CIR) is a not-for-profit organization that works in underserved and conflict-affected regions worldwide to meet the needs of people with disabilities. The ...
more »
