As I'm sure some of you, maybe many of you, have not seen a plastic wrap sculpture before, I will show you some pictures first.
Remove these ads by
Signing UpStep 1Materials
Plastic wrap (What brand is up to you, some sticks better than others and sometimes you may not want that... so it's all up to you)
Packing tape (go for the clear packing tape for a nice clean look)
Scissors (it's not pictured but you need 'em)
An item to wrap (if it is your first/second try make sure to have something you don't mind getting cut a little. After you have some practice it is easier not to cut things)
It's a two person job at minimum and requires a LOT of care (it's recommended that you use a mannequin).
The model is wrapped the same way as anything else, but one section at a time (arm, leg, torso, etc.).
Continually ask about tightness and bloodflow! If it is too tight, it will be difficult to remove later.
After wrapping, carefully (CAREFULLY) use scissors to remove.
One of them is a Techno Viking Helmet with voice-activated glowing horns: http://www.instructables.com/id/be-ZIGGY-STARDUST-gone-SPACE-VIKING-Volume-Indica/
Modern art gallery
I tried it out today, I made a bottle and a spoon. The spoon turned out a little crooked, but meh.
Here they are!
