3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plastic bag bag
Step 4Add handles
Add handles
Note: If you prefer, you can count stitches to place the handles, but I've found that it's hard to accurately pinpoint the edge of the bag, and I get better results just eyeballing the bag and starting the handles where it looks right. Also note again that I am lazy and not particularly fussy.
Once the body of the bag is complete, you'll add the handles. Integrated handles work best for grocery bags, because they're more secure and less likely to unravel when you're carrying heavy loads.
To start the handles, flatten the bag, then measure equal distances from each edge to indicate where to start the handles. Place four markers at the positions where the handles begin. The handles will work outward, so you may want to make the openings slightly smaller than you picture the finished product. See the second photo for an illustration.
Continue crocheting the next round as usual, but when you reach the first marker, crochet a chain stitch, slightly longer than the gap between the first and second marker. See the third photo for this.
Attach the chain to the second marker, then continue crocheting until you reach the next marker, then chain stitch as with the previous, and attach again at the final marker. Do not make the handles too long, as they're pretty stretchy.
Crochet two to three more rounds, until the bag handles are the desired thickness, making sure you have the same number of rows in each handle.
Once the handles are complete, continue crocheting to the edge of the bag, then finish off, and you're done.
Now keep making these until you run out of disposable bags.
6 comments
Nov 22, 2010. 12:19 PMkaldirris says:
I saw a post elsewhere that suggested laying out a few plastic bags (folded to the desired size) between two old towels, and ironing them on medium-ish heat - it fuses the plastic together, thus making a strong piece of plastic. I bet that would work very well as a bottom support for these bags. In fact, when I finally get around to using the 3 - 8" diameter plarn balls I already have, I'll let you all know how it turns out! LOL
Aug 5, 2009. 7:03 PMzimitt says:
I have noticed that plastic bags have a grain (for lack of a better term). If you try to tear a bag in the up and down direction it will follow the tear in the same up down direction and tear quite easily. If you try to tear it from side to side it will not tear and will usually change to a up and down direction. Cut a long strip of bag 2" wide out of plastic from both directions. Do a test. It is much easier to break the one cut from the horizontal. Just think how strong the handles of a shopping bag are. Your handles should not be breaking when they are many times as thick as the original bag. I know it wont be so easy to make loops that join together but if you change the direction of your strips you will have a much stronger bag. Maybe you could just change the direction for the handle part. Just my 2 cents.
Aug 30, 2008. 3:38 AMtea_lover says:
Only problem with these bags is that the plastic stretches if you put anything remotely heavy in them, and the handles tend to snap too. But thank you for putting up this instructable. Do you know you can use old VCR tapes to make bags too?
Sep 1, 2008. 6:07 AMjeff-o says:
Could you stitch around some sort of stronger supporting structure, like a coat hanger or something? That might help distribute the weight of the bag across the entire body of the bag, instead of just the handles. It would be like an underwire on a bra.
Sep 1, 2008. 9:52 AMjeff-o says:
I suppose you're right, if the bag is stretching too much then you're trying to carry too much! A coat hanger was just an example though, you could re-use any stronger material that's lying around: a piece of extra twine, some binding straps, pieces of packaging, whatever. I also should have mentioned, this is an excellent use for old plastic bags!
Aug 30, 2008. 4:00 AMYellow84 says:
Wouldn't the bag become stronger? It looks like she twisted the plastic when she crocheted it.
Aug 30, 2008. 7:32 PMtea_lover says:
It does make it slightly stronger, but the plarn still stretches. I have a friend who makes these bags a lot (I have made one but did not like the way it stretched, I just use my plarn to make scourer pads now) and the way she got round this was making the plarn wider (so 2-3 inch wide strips) as well as twisting, AND lining the bag with fabric (calico is her fabric of choice, though she does use scraps such as old jeans and duvet covers).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:lisarea
