Introduction: Plastic Bottle Multipurpose Hanging Decoration
Picture of Plastic Bottle Multipurpose Hanging Decoration
This is a lantern or a planter and is a great accessory to have in the backyard or any area you like. I simply cut and carved out the plastic container (this is a 5 litre water jar), folding plastic in ways to make it appear in different shades I used a drawing marker, cutter, glass paints, acrylic paints, pollen sticks used for making flowers, Mseal/ Air dry clay, PVA glue, varnish and beads and other embellishments.
Step 1: Plan
Picture of Plan
I simply took a marker and drew fairy images, butterflies etc all over the bottle. Once done, I cut some parts of the bottle to turn it out. The trick it to keep the core strong so that your base , top and four connecting pillars are strong just like when you build a house. Then the structure can take any amount of weight you like. I also made a similar one to stack my gardening tools!!
Step 2: Decorate
Picture of Decorate
You could use all your imagination here. If you like too use it as a lantern use glass paints for a translucent effect. Else you can try decoupage or other embellishments. I also made small fruits, spider, snail, birds, flowers etc with clay and stuck it to give a 3D effect.
If your bottle does not have a hanger you could simply punch holes and pass a wire or thread. Mine was specifically made for the kids' backyard area, hence I liked to work on a fairy theme!!
About This Instructable
483views
5favorites
License:
More by Sunglowart:PizzalingsGinger LiqueurSourcherry Liqueur -Ginjinha
Add instructable to:
