3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Plastic bottle funnel
Step 2Prep the cap
Prep the cap
Carefully determine the proper drill bit diameter to use. If you have calipers or another accurate way to measure then use it. But I don't. I tend to rely on the rack that my drill bits came in to approximate the right size bit. Of you can hold them up to each other and eyeball it. Or put the drill bit and pen on a level surface (check with your level first) and with them close to each other - perhaps an inch or two apart. Then put the level on and make sure it is still close to level. In all cases you actually want the drill bit slightly smaller than the pen.
If you have a vice you can try putting the bottle cap in it. Or adjust a set of locking pliers (Vice-Grip type) so that they will hold but not crush the cap. Or screw it onto the bottle and bravely drill the cap while holding the outside of the bottle. I, of course, would prefer that you find some safer way to do this though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:zieak(Zieak's site)
I like making things out of items that would have otherwise been discarded. Check out my other projects! Now a PE teacher in Mongolia! I don't have much time or even the resources to make much any m...
more »
