As everyone knows wasted heat is wasted money, energy, and comfort.
I was trying to find the greenest, most cost efficient way to insulate my house. While searching for insulation i discovered that gases are really the best insulators. (other than a vacuum thanks Gofish)
After scratching my head a couple of times trying to figure out how to seal off air in my 1960s home, I though duh empty bottles.
Remove these ads by
Signing UpStep 1: What you will need
2. Empty attic space
3. Filler, this can be almost anything,
like expanding foam or blown in insulation
but for more recycling i used plastic bags.
Visit Our Store »
Go Pro Today »
Would lightly scoring the interior side of the bottles be enough for the "plaster" to stick? Any low cost suggestions would be appreciated
Go here, be inspired!
THE SAME IN CASE OF FIRE FROM THE BELOW ROOMS....
NO, I THINK THE ONLY MAIN CONCER OF THIS SOLUTION IS THE WEIGHT ONE HAVE DISTRIBUTED ALL OVER THAT PLACE, THA T MAKE ME FEEL A BIT UNCONFORTABLE...
BY THE WAY: NICE IDEA !
IMPROVE-ABLE BUT NICE!
Rich
Course there is the flip side to a sealed tight home. It traps moisture and indoor pollutants.
Before loading your addict with plastic let me suggest an experiment"
Take a plastic walmart bag twist it into a rope then light the bottom of the rope on fire hold the burning rope over your hand for say 30 seconds. after that experiment imagine thousands of those ropes burning over your bed over your body.
Also consider the air trapped in the bottles, every time one of those bottles rupture during a fire more oxygen is going to be released to fuel the fire, in a normal fire that space would have been filled by carbon dioxide slowing the rate of burn of the contestable materials, by storing the air in the bottles you would be providings more oxygen to the fire causing for a hotter and much more violent fire.
Maybe those new aluminum beer and soft drink bottles would be ideal for what you are trying to accomplish.
Sorry to poo poo on your Idea but I do not want to see you or other people reading this get killed.
Google "great white club fire" 100 people were killed in less then 5 and a half minutes because the owners of the building insulated it with plastic.
As for the plastic Vs fiberglass issue. Insulation is sold in many forms besides fiberglass all of them burn and a lot of them draw bugs. For example there is Styrofoam it goes up like a torch. And the bug drawers are made of shredded newspaper or recycled bluejeans or any other kind of fabric. The only problem with plastic i can forsee is plastic isn't stable. It outgasses as the gas leaves the plastic it become more and more brittle. So over time if you put your weight onto the bottles they will crush instead of flexing. So i would make sure that they are in a place you are not going to be having to travel over.
so i say, fill em with water for better heat retention
such a good idea, it would be a shame to let something like a fire hazard get in the way.
Sorry to have to mention this, but You don't want to use pet bottles and plastic bags as insulation. It will burn horribly, causing tons of toxic smoke that potentially will killyou in your sleep. See that bx cable running from the fixture. If that ever shorted (it's safe enough) but if it did.... Also contact your insurance company. Will they still insure you if you used non industry tested insulation.... Just things to consider.
Blown in cellulose uses boric acid as a fire surpressant. Glass blown insualtion has very low fire properties. It's basically glass.
Did you know that most fire deaths are from smoke inhalation. Even if you make it out, you've inhaled toxic chemicals. Firefighters who have to come and save you are also at risk, of getting lung cancer.
I Love those new polystyrene foams also, but they burn just as bad as this.
Code says any foam panels have to be covered with sheetrock. WHy....
it gives you time to get out before it bursts into flames.
Antnoio
this stuff is good for fire resistance then using it as a base for the bottles.
drywall----------------- recycled
+bottles----------------- recycled
+air--------------------- free
+plastic bags----------- recycled
+expanding foam------ ?
=insulation for cheap
