3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Play the French Can Can Using an Arduino and Buzzer
Step 5Create Starting Sketch
To answer the question, "How do I make the buzzer make noise?", I did a Google Search for [CEM-1203 arduino make noise]. Near the top there was a blog link labeled Buzzer Arduino Example Code written by Ron Faludi. Ron shared his code here (Thanks Ron! You're awesome!).
Copy between the lines:
----------------copy after this line----------------
// Buzzer example function for the CEM-1203 buzzer (Sparkfun's part #COM-07950).
// by Rob Faludi
// http://www.faludi.com
void setup() {
  pinMode(4, OUTPUT); // set a pin for buzzer output
void loop() {
  buzz(4, 2500, 500); // buzz the buzzer on pin 4 at 2500Hz for 1000 milliseconds
  delay(1000); // wait a bit between buzzes
void buzz(int targetPin, long frequency, long length) {
  long delayValue = 1000000/frequency/2; // calculate the delay value between transitions
  //// 1 second's worth of microseconds, divided by the frequency, then split in half since
  //// there are two phases to each cycle
  long numCycles = frequency * length/ 1000; // calculate the number of cycles for proper timing
  //// multiply frequency, which is really cycles per second, by the number of seconds to
  //// get the total number of cycles to produce
 for (long i=0; i < numCycles; i++){ // for the calculated length of time...
    digitalWrite(targetPin,HIGH); // write the buzzer pin high to push out the diaphram
    delayMicroseconds(delayValue); // wait for the calculated delay value
    digitalWrite(targetPin,LOW); // write the buzzer pin low to pull back the diaphram
    delayMicroseconds(delayValue); // wait againf or the calculated delay value
----------------copy before this line----------------
Copy and paste this code into the Arduino IDE, and save the sketch as some descriptive name like 'buzzerExample'. Descriptive names will help in the future once you have many files in one place to sort through.
1 comment
Nov 27, 2011. 2:15 AMmichielrutjes says:
The guy's name is "Rob", not "Ron" Faludi ;) Excellent instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Ultrus(Christopher Stevens)
Web developer and designer who loves renovating and empowering over-sized web projects. Experience in developing and integrating ground breaking creative solutions online. Enjoys solving complex devel...
more »
