Playable Cardboard Ukulele... by eplunkett
Featured
Step 21: Glue neck...
Glue the neck into the notch in the body.  While glue is still drying, install the screw through the back.  The screw should go through most of the neck, but not poke out of the top.  This joint is very critical, so check alignment often during the gluing and use tape to hole in the proper position.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
