Playing Imperial March on a Fast Switching Valve
2,931
21
Published
Introduction: Playing Imperial March on a Fast Switching Valve
I thought that there have been dozens or Imperial marches played by floppy drives or step motors so I might as well do something new...
The sound you hear is produced by high pressure air rushing out of the valve - it opens and closes very very fast and produces sound. The valve I used here is Festo's MHE3-MS1H-3/2G-QS-6.
Its switch on time is 2.3 ms and it switches off in 2.8ms - very very impressive piece of hardware and they are pretty pricey - luckily I got it for next to nothing.
1. The circuit is very simple - just a ULN2003A used as a driver for the valve. Check the diagram.
(note that I had to substituted the valve with a solenoid - but hey it's a SOLENOID valve after all. Ohh and by the way - if you don't have a pneumatic valve the circuit will work with just a regular solenoid - just mount it so that it strikes a metal object and it should produce sound too ).
CIRCUIT DIAGRAM ->>
http://s7.postimg.org/p459aly0r/ULN2003a_Driving_a_relay.jpg
2. Here's the arduino code (it's a slightly modified version of a sketch created by Carlton Shepherd) - just copy & paste build the circuit as described and it should work just fine
    const int c = 261;
    const int d = 294;
    const int e = 329;
    const int f = 349;
    const int g = 391;
    const int gS = 415;
    const int a = 440;
    const int aS = 455;
    const int b = 466;
    const int cH = 523;
    const int cSH = 554;
    const int dH = 587;
    const int dSH = 622;
    const int eH = 659;
    const int fH = 698;
    const int fSH = 740;
    const int gH = 784;
    const int gSH = 830;
    const int aH = 880;
    const int buzzerPin = 2;
    int counter = 0;
    void setup()
      //Setup pin modes
      pinMode(buzzerPin, OUTPUT);
    void loop()
      //Play first section
      firstSection();
      //Play second section
      secondSection();
      //Variant 1
      beep(f, 250);
      beep(gS, 500);
      beep(f, 350);
      beep(a, 125);
      beep(cH, 500);
      beep(a, 375);
      beep(cH, 125);
      beep(eH, 650);
      delay(500);
      //Repeat second section
      secondSection();
      //Variant 2
      beep(f, 250);
      beep(gS, 500);
      beep(f, 375);
      beep(cH, 125);
      beep(a, 500);
      beep(f, 375);
      beep(cH, 125);
      beep(a, 650);
      delay(650);
    void beep(int note, int duration)
      //Play tone on buzzerPin
      tone(buzzerPin, note /4, duration);
      //Stop tone on buzzerPin
      noTone(buzzerPin);
      delay(50);
      //Increment counter
      counter++;
    void firstSection()
      beep(a, 500);
      beep(a, 500);
      beep(a, 500);
      beep(f, 350);
      beep(cH, 150);
      beep(a, 500);
      beep(f, 350);
      beep(cH, 150);
      beep(a, 650);
      delay(500);
      beep(eH, 500);
      beep(eH, 500);
      beep(eH, 500);
      beep(fH, 350);
      beep(cH, 150);
      beep(gS, 500);
      beep(f, 350);
      beep(cH, 150);
      beep(a, 650);
      delay(500);
    void secondSection()
      beep(aH, 500);
      beep(a, 300);
      beep(a, 150);
      beep(aH, 500);
      beep(gSH, 325);
      beep(gH, 175);
      beep(fSH, 125);
      beep(fH, 125);
      beep(fSH, 250);
      delay(325);
      beep(aS, 250);
      beep(dSH, 500);
      beep(dH, 325);
      beep(cSH, 175);
      beep(cH, 125);
      beep(b, 125);
      beep(cH, 250);
      delay(350);
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    The link to the circuit diagram is dead
    The picture was there all the time but for some reason instructables doesn't allow images on video tutorials. I can add them and it has been but it just isn't displayed That's why I uploaded it somewhere, but, as you pointed out, didn't work. It's now fixed
    My friend, I think that you may be out of your mind! Awesome Instructable! I've sold pneumatic valves and cylinders for almost twenty years now, and this is the first time that I've seen something like this portrayed so well. Keep it up!
    Ken
