Here's how I tackled the Pledge Fabric Sweeper and won.
You'll need a 3/4" Neopreme Rubber Grommet, a #7 Tapered Cork Stopper, and a pen knife.
Remove these ads by
Signing UpStep 1How-To Make It Happen...
Hold the rubber grommet against the top edge of the "flat side," where the <- SLIDE -> label resides. This point is technically along the "bottom" of this label. Trace the grommet with a pen or marker.
Carefully cut along the inside of the circle you just put down...I'd take it in about an 1/8 of an inch(?) -- I apologize for not having the exact measurements here.
Fit the grommet into place and gently cap it off with the #7 cork stopper.
When your Fabric Sweeper is full, pop the cork and vacuum out the contents!
That's pathetic.
Good instructable.
If you have an adjustable iron (and extra tip) that's perfect, if not use a standard iron before it heats all the way up or use a light dimmer.
This would work
http://www.instructables.com/id/The-FX-Light-Dimmer/
