Plexi-glass Box 4 Home Audio Amplifier With Power Supplay
1,746
30
7
Posted
Introduction: Plexi-glass Box 4 Home Audio Amplifier With Power Supplay
Home made Plexy-glass box with power supply and audio amplifier.
The idea was born because in house cinema I had no SUB. The system is 5.1, but the SUB was not amplified output. Variants have been two. Buy an active SUB, or just bought an amplifier and make a box
Step 1:
First of all, I bought 2x50w Class-D amplifier, which has a working range from 10VDC to 26VDC for less than US $7
Of course, the 12V power supply has much less gain. But the test was authorized.
So I made a small body of plexiglass. Most of the material I picked up from my workshop :) so that the product is not exactly profi
Step 2:
The amplifier has been tested, but missing the right power supply. Circuit for power supply was copy from internet .
In view of the fact that when you switch the amplifier sounds less bang in speakers (what is normal for a bad class) so, I added a circuit that delays the activation speakers.
Step 3:
So ... the circuit is assembled, but not in the case. In the garage I had some plexi glass panels. Dimensions were appropriate. For plexi bend several variants of. it can be bent with a strong blow dryer or use of the filament (video)
Step 4:
And in the end it was necessary to have all screwed to the chassis. Again, I used the resources available in the garage. Some of the spacers, some wire and that's it.
  • Spotless Contest
    Spotless Contest
  • Pocket-Sized Contest
  • Microcontroller Contest
5 Comments
What would i need to change to make it 200W?
Woah I bet the sound is amazing, not to mention this is the coolest looking amp I've ever seen. Welcome to instructables, I hope we see more of your awesomeness soon!
TNX MsSweetSatisfaction :)
The sound is pretty good. Given the fact that my SUB is mono, I had bridge output. This is the L+ and R- so the output power is 100W.
