Introduction: Plinth Eastwood Nr. 0059
Picture of Plinth Eastwood Nr. 0059
This desk-lamp is build by the keep-it-simple-and-stupid (KISS) principle. It is build quite similar as nr. 0056. The only differences are the dimensions of the wooden feet and size and angle of the lampshade.
Step 1: The Plan
Picture of The Plan
First of was some doodling. The plan was to make a lamp for work at the office. The wood is a fine piece of oak. Dimensions are 12x18x2400mm. The third drawing shows the length and angles of the wood-pieces of one feet. Don't forget to make two of those ;).
Step 2: Glueing
Picture of Glueing
First step of the assembly is glueing the wood-pieces together. I use clear tape on the combined parts, grippers and construction-glue in a disposable syringe to get a tight result. The tape prevents the grippers of becoming a part of the project..
Step 3: Toothpicks
Picture of Toothpicks
2mm drill-holes are being made to accommodate toothpicks. This makes a stronger bond and looks fancy as well! The coned ends of the toothpick are cut of. The same glue is used to bond it all together. After drying the 'toothpick-residu' is cut of with an iron saw.
Step 4: Test Fit and Sanding
Picture of Test Fit and Sanding
The lampshade is again made of a lovely biodegradable saladebowl. The hawk-eyed reader noticed that this lampshade is a bit larger than the one used for nr. 0056. Make markers by using a fineliner pencil and the contour of a little piece of oak. Two rectangular shaped entries need to be cut with use of a small hobby-knife. This is where the feet are inserted. A little bit too small is better than a bit too big. Next is sanding the wood for a flawless finish.
Step 5: Final Assembly
Picture of Final Assembly
Here we jump to the final assembly. The shade has gotten a paint-job. Make a power-cord and connect a lamp-fitting to it. Wait with assembling the wall-socket adapter. Important step is filling the lamp-fitting with hot-glue to make a solid base. Let it harden before glueing the fitting on the inside of the shade.
The (in the meanwhile shortened) feet are inserted in the shade and fixated with hot-glue. This hardens within minutes. Be sure that the position of the feet are symmetrical. Next is a 7mm drill-hole in the shade between the two feet. Insert the power-cord and glue the fitting in the shade. I use a combination of construction-glue and hot-glue for a strong bond.
Step 6: Sweet :*
Picture of Sweet :*
And there we witness the birth of another fine Plinth Eastwood. I love my little ones!
Warning: be safe and don't leave this DIY unattended.
Dinnersnack (author)2016-04-04
Great lamp. very clean lines and design. Also, the background wall, is that wallpaper or something else. I love the design.
Nice to read that you like the lamp. The background is embossed wallpaper. After nearly a decade we are still madly in love with it..
fraser02 (author)2016-03-27
woooow that is a neat result i am so making this!
thanks heaps for sharing!:)
PlinthEastwood (author)fraser022016-03-27
I'd be honored Fraser02.. I love to see the end result.
fraser02 (author)PlinthEastwood2016-03-27
I am working on it right now...
fraser02 (author)fraser022016-03-27
I may actually use the frame design you have on here, but use a torch for the light, without a beam but made to still look stylish... because i have already cut 2 light wires trying to get them off old lamps!!
PlinthEastwood (author)fraser022016-03-28
I'm curious.. Keep me posted!
ixanderino (author)2016-03-26
Mooi sober ontwerp!
Sober!? Ik vind het 'meer' minimalistisch.. ; )
About This Instructable
7,570views
122favorites
License:
More by PlinthEastwood:Plinth Eastwood nr. 0060Plinth Eastwood nr. 0022Plinth Eastwood nr. 0033
Add instructable to:
