Plywood Hexagon Lamp
6,086
116
18
Posted in WorkshopLaser-cutting
Introduction: Plywood Hexagon Lamp
About: Industrial Design student at Rotterdam, the Netherlands. Completed Fashion Tailoring school before, now more aimed at learning about product. Becomes quite enthusiastic when sharing ideas. Talent for foreig...
Make this hexagon lamp in 11 simple steps!
#stadslabrotterdam
Step 1: You Will Need:
Hammer
Wood glue
Superglue
Nails
Screws
Screwdriver
Hand drill
Ruler
Sandpaper
Magnet
Piece of metal
Light bulb E14 + cord
Filament for 3d printer ( I used white PLA 1.75 mm)
Poplar plywood panels 300x600 mm
Thickness should be:
2 planes 12 mm
1 plane 4 mm
White acrylic sheet (30% light transmission, satin finish)) 400x700mm
Thickness should be 3 mm
Lasercutter
3d-printer
Sander (or use sandpaper)
Step 2: Laser Cutting
Lasercut these files on the 12 mm wooden panels.
Step 3: Laser Cutting
Lasercut this file on the 4 mm wooden panels.
Step 4: Laser Cutting
Lasercut this file on the plexiglass sheet.
Step 5: 3D Printing
Print these files with your 3D printer.
Also glue in the magnet and piece of metal.
Step 6: Glue
Glue the wooden frames together.
Important note!!
There are two frames sized 250 mm.
Only glue one of them!
The other one will serve as a lid later.
Step 7: Closure
Drill holes for the screws on the inside of the 250mm frames.
Attach the 3D printed closure parts with the screws.
Step 8: Hinges
Using the nails, attach the hinges to the the opposite side of the frames.
Step 9: Glue Again
Glue the bottom and lid on.
Step 10: Almost Finished
Drive a screw into the lidframe.
Place the plexiglass sheet into the lid.
The closure and screw will hold it in place.
Insert the light bulb socket trought the hole, then insert light bulb.
Step 11: Finish!
Turn on the lights and voilà!
Good luck and have fun! :)
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    18 Comments
    I love this kind of instructable; a great execution of a simple concept. It makes me want to take this idea and put my own spin on it. I'm thinking dyed wood layers with the sides sanded smooth.
    Thank you! :)
    Please send a picture if you do make it!
    Would be happy to see it :)
    Thank you I think it is wonderfull I am pensioner looking for totally free woodworking ideas with plans please help me to help my self
    Thank you! :)
    If there is anything that needs to be changed in the files, for example you want to make a smaller or bigger hexagon lamp, or a pentagon or triangle, then I will be happy to change the files and send them to you. :)
    Thank you :)
    I remember your tv from the exhibition, looks really cool! :)
    Nice design and clear Instructable, thanks!
    Thank you!
    your Light-Up Dry Erase Board is really cool!
    Very unique lamp and great first instructable!! I can't wait to see what you come up with next! Thank you for sharing your project!
